Old 04-18-2009, 09:26 AM   #1 (permalink)
calc liter per hour by MAP - how?
I´m not sure if I´m right here but I´ll try in my bad english.
my car (MG TF) has no MAF-Sensor so I couldn´t use the formula:
GPH = MAF * 0.0805
but I read, that MAP (mainfold air preasure) could be used to calc MAF
MAF = RPM * MAP / absolute temperatur (PID15)
if I do this MAF = 960 * 37 kPa / 27 °C = 1315
I know a engine like my 1,8L 135PS need 2 oder 3 Liter, so GPH = 0.6
with this should MAF be 7, if I calc with my OBD-value I got 1315, hopefully everyone unterstood the problem ...
Do someone know a way, to calc with speed, rpm, mainfold air preasure and temperature GPH or Liter per hour ... the change form gallone to liter is not my problem???
Reading a MAP sensor dcb Instrumentation 10 09-19-2010 09:50 PM
MAp sensor to 5v power momentary switching Dust Off-Topic Tech 0 10-10-2008 03:41 AM
