EcoModder.com
-   Motorcycles / Scooters (https://ecomodder.com/forum/motorcycles-scooters.html)
-   -   Add catalytic converter to a motorcycle? (https://ecomodder.com/forum/showthread.php/add-catalytic-converter-motorcycle-37746.html)
TurnNBurn 08-09-2019 12:12 AM
So I'm just getting into motorcycling and have a Honda 919 (CB900F). It's a 2007 model. I'm concerned about emissions and looking for a small project and was wondering how feasible it would be to add some sort of catalytic converter to it. Is it even possible or worth it? I know modern bikes ship with them standard now. But I can't find any sort of universal cat for sale that I can splice into the exhaust system.
oil pan 4 08-09-2019 12:46 AM
Does Vegas have a smog problem?
Frank Lee 08-09-2019 01:03 AM
How about this one?
https://lovestitches.files.wordpress...a9b8.jpg?w=500
TurnNBurn 08-09-2019 10:43 AM
Earth has a smog problem
Stubby79 08-09-2019 11:13 AM
Found this pretty easily...
http://www.ebay.com/itm/Motorcycle-C...g/352386503832
California98Civic 08-09-2019 11:50 AM
Originally Posted by Stubby79 (Post 604211)
That's interesting. How would you judge whether it will be effective? Is there a flow rate standard or something?
OP: good on you giving a damn about emissions. We should.
EDIT: Also, this: https://news3lv.com/news/local/repor...-cite-progress
TurnNBurn 08-09-2019 02:46 PM
If all it means is splicing in 3-6 inches of catalytic converter into my exhaust, why shouldn't I do it?
I want a zero motorcycle, but it's not feasible here. I'm in an apartment, no garage, no charging station, and the zeros are still too expensive. And after the 5 year battery warranty there's no clear upgrade/refurbishment program.
rmay635703 08-09-2019 03:24 PM
I thought about putting a cheap reliable antique 2 way cat onto my 2 cycle Subaru 360 just because dimensionally it would fill the same spot as the rusted out expansion chamber
Sadly the places that market cats don’t seem to have a dropdown of size/type/etc of cats because of the must meet OEM spec BS.
Unfortunate since the 2 ways are only like $15-20 and I would throw them on in place of mufflers on old little cars if I could easily find them in the correct dimensions
Stubby79 08-09-2019 03:28 PM
You could also find one for a Geo Metro, which has a similar sized engine, and splice it in.
oil pan 4 08-09-2019 04:44 PM
Smog isn't a global pollutant.
