EcoModder.com
-   EcoModder Blog Discussion (https://ecomodder.com/forum/ecomodder-blog-discussion.html)
-   -   Adding an overdrive (BW T-19 to ZF-5 transsmission swap) (https://ecomodder.com/forum/showthread.php/adding-overdrive-bw-t-19-zf-5-transsmission-23037.html)
SVOboy 08-23-2012 04:30 AM
If you’ve never driven a vehicle more than a couple decades old, you probably take overdrive for granted.* You may not even have a clear idea what that term means.That 5th or 6thgear, with a ratio smaller than 1.0 (meaning the driveshaft is turning faster than the engine) lowers the engine RPM speed on the [...]
More...
bobo333 08-23-2012 06:31 AM
YES! This is exactly what i need to do in my '77 F100!
i will be watching closely, thanks
