adjusting acc. pump shot on Holley/Weber carb....
Does anyone know how to adjust the accelerator pump shot on a Holley/Weber carb? I'm using this carb on an '86 Toy truck with header,Jacobs ignition,And somender grooves and power lynz on intake manifold and head.I have gotten a best of 31m.p.g. SO FAR!!!
I no longer have a DF series carb in front of me but I do know you could adjust it with different holes in the linkage on my Edelbrock which was really a Weber.
I have tried to adjust the idle jets but this carb does not have them on the sides like all the pics i have seen.Where would it be at?
Amazon link to webber carb manuals...
Amazon.com: Webber Carburator: Books Tune a Weber 32/36, Weber 34, Weber 38 or Holley Carburetor looks like a good option for the specific stuff on the small progressive two barrels. Webber brand carbs do not adjust like a holley, rochester or any American unit, I fix race cars all the time with carburation issues, its almost always because folks don't understand some of the twists which are non intuitive in the webber. The Holley Webbers come in about 3 or 4 families depending on age, and each of them has its own devious little tricks. There is a lot about these under the Jeep forums here and there because a lot of jeeps got them to replace the POS stepper motor variable venturi rochester/ford abomination that came on them. Good luck,,,! Dave |
