EcoModder.com
-   -   Adjusting ignition timing on a distributorless engine (https://ecomodder.com/forum/showthread.php/adjusting-ignition-timing-distributorless-engine-12899.html)
Daox 04-08-2010 01:36 PM
So, I semi-recently got an adjustable cam timing pulley for the Paseo. This is going to alter some things and I'm thinking it might be advantageous to tweak ignition timing as well. What are my options?
comptiger5000 04-08-2010 04:51 PM
Typically the only option that doesn't screw with anything else is to have the timing values changed via computer tuning.
Daox 04-08-2010 04:57 PM
Yeah, I kinda figured that. Are there any piggyback systems that only handle ignition timing? I'd rather not have to get a full piggyback, but I suppose that would work too. Kinda looking for something inexpensive. The cam pulley cost ~$100, so I'd rather not spend another $100 on adjusting ignition... But, it looks like I might have to.
