Old 01-19-2013, 02:57 PM   #1 (permalink)
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
16X4 Lcd with Mpguino
Greetings to all members,
I've recently ordered a freeduino in order to built a metric mpguino.
The think is that i own a lcd screen that is 16X4 instead of the regular 16X2...
It would be nice to have all the information i need in front of me but can i use the bigger lcd screen?
Old 01-29-2013, 07:24 PM   #2 (permalink)
Coal - '97 Honda Civic HX
Since no one else has said anything yet, I figured I would at least try a tiny bit to help.
I had previously read a thread (which of course I am unable to find now), where someone had asked the same thing. Basically there are two parts:
1.) The screen has to have the same number of pins as the mpguino (it is either 8 or 16).
2.) The base code for mpguino would need to be modified to output to 4 lines instead of 2 and then re-flashed to the mpguino. I saw a different thread where someone had taken the "UINO" (base base code) and modified it for more lines, but that was from quite a few years ago.
So, it CAN be done with most of the responsibility being if the screen has the same number as pins as the PCB of the mpguino.
Sorry I don't have the links to the threads, but they are out there.
Mugg
The Following User Says Thank You to Mugg For This Useful Post:
stargazerf3a (01-30-2013)
Old 01-30-2013, 10:26 AM   #3 (permalink)
Found the thread!
Below is the thread and the response from Meelis...
ecomodder DOT com/forum/showthread.php/mpguino-20362-2.html#post341628
Hi,
I personally have not seen a point to add bigger screen - you see 4 values in one screen and you just flip between screens to see other values.
If this larger screen has standard 16 pin interface on top of it, then it probably works, but it needs code changes to put 8 values to one screen.
Old 01-30-2013, 10:36 AM   #4 (permalink)
Thank you Mug!!!
I was searching but you've got me first
My lcd has 16 pin so I guess i'll built a BIGLCDMPGuino
Old 01-30-2013, 09:42 PM   #5 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Yes, that was me asking! But my thoughts were two-fold. First, to display more values on the screen at once, so I can get a look at more without having to flip screens. Second, I was thinking of my dad, and I was considering doubling the size of all the original 16x2 MPGuino screens so that everything was larger and easier to read. Meelis was the one I asked; he's worked up some additional parameters to display.
stargazer, I'm interested to see the final product...
Old 01-31-2013, 04:55 AM   #6 (permalink)
Goodmorning Econoram,
I am not really sure i'll use the bigger screen cause i may have a problem with space on the dashboard but i'll try to built it anyway just to help others use different size screens or graphic lcds maybe to look OEM...
Old 02-04-2013, 07:38 AM   #7 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Interesting idea... Keep us posted about the results.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 02-04-2013, 07:30 PM   #8 (permalink)
halos.com
No worries. Meelis pointed me to a larger 16x2 I think I might try...
