Aero Front End Possibility?
http://www.speedwaymotors.com/eccSto...05FUSION_L.JPG
http://www.speedwaymotors.com/p/5331...ml?itemNo=nose That bumper has a pretty good taper to it. So it would be possible to just get the bumper only for $130 then fit it to an existing car. Cutting out the headlights and putting a lexan cover for the stock headlights would probably work out. Anyone crazy enough to try it :) I would but I already have other plans for my car, plus I don't want to spend 100 bucks on something I could probably make here way cheaper with the setup I have in my shop. But it could be a possibility for anyone trying to do some radical aero mods to their car. |
I'm pretty sure you're crazy enough, :)
saw those too. called and they come in 4 pieces and would fit the front of the vw perfect. have to build a frame to hold the parts.
I'm still waiting for a 92-95 Civic Fiberglass one piece front end to show up on craigslist or ebay locally for cheap. Then I'll go that route on my VX.
http://www.frankscustomfiberglass.co...ront%20End.jpg http://www.frankscustomfiberglass.co...ide%20view.jpg But the aero parts you show would be good too. I'd just worry about how much poundage they add in downforce at highway speeds? |
thats pretty neat, to bad i dont have anything to try it on
TomO what's that front for? And How much?
aero front end
I don't think the fascia allows enough clearance for ramps and gutters.Its a beautiful unit,however I'm afraid it would end up in the street,ripped from the car.'Probably better for the track.
civic front end
That big flat area on that Civic front end isn't ideal for low drag (and is great for smashing bugs). You need to have a rounded nose like you can see on the Aptera and on my car.
