EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Aero Kit For Ford Fusion Hybrid (https://ecomodder.com/forum/showthread.php/aero-kit-ford-fusion-hybrid-10851.html)
srortega 11-03-2009 02:51 PM
As an undergrad in college, I had the privilege of twice attending the annual Specialty Equipment Manufacturers Association (SEMA) Show in Las Vegas. SEMA is mostly known for wild, outlandish, and powerful versions of street cars; it isn’t the kind of place you go to find people discussing fuel efficiency and hybrids.
But 2009 is a year of reckoning and big changes are afoot in the auto industry. One sign of the times: M&J Enterprises has brought to this year’s SEMA a Ford Fusion Hybrid equipped with an aero body kit to reduce drag.
Aerodynamics play a big role in fuel efficiency, and a few tweaks can make a large difference in the grand scheme of things. We’ve seen body kits for hybrids before, such as the Tommy Kaira Prius, but this is the first one I’ve heard of for the Ford Fusion.
The unnamed body kit uses a series of different body modifications, such as heat-reflective paint and windows, and air splitters to reduce drag. Less drag means higher fuel efficiency, and most drag actually occurs beneath the car. M&J claims that all these parts are actually lighter than the factory stock parts, or eliminate petroleum-based products. The Fusion Hybrid already has a promising eco-footprint with their recycled seats and great gas mileage, though how much this bodykit will improve things has yet to be seen.
Source: M&J Enterprises
MetroMPG 11-03-2009 04:19 PM
srortega: Interesting.
Did you write that text? Or is it copied from elsewhere?
mcrews 11-03-2009 05:17 PM
I believe this is the source:
Written by Christopher DeMorro
Published on November 3rd, 2009Posted in Hybrid-electric EVs
found the full article (from 1st poster)
M&J Enterprises Builds Aero Kit For Ford Fusion Hybrid : Gas 2.0
srortega 11-03-2009 07:31 PM
Sorry I should have sited the source, I got it from a Gas 2.0 RSS feed.
donee 11-04-2009 07:05 PM
Hi All,
You guys all know who Chris DeMorro is? Hints: Central Connecticut State University, Rush Limbaugh and George Will ...
