Aero photos from El Mirage SCTA finals
18 Attachment(s)
Just a handful of pics arranged in an order meant to help you see aero features. Several pics are of the dust trailing wakes of the cars I photographed before their runs.
Here is the wake of the streamliner motorcycle featured in the attached pics: http://ecomodder.com/forum/attachmen...2&d=1384151834 Here is the wake of a roadster: http://ecomodder.com/forum/attachmen...3&d=1384151876 Here is the wake of the yellow Austin van featured in the attached pics: http://ecomodder.com/forum/attachmen...4&d=1384151892 All images taken from almost the same distance, give or take a dozen yards or so... |
Great pics! Thanks for sharing. Any additional info on the vehicles in the pics?
Can't really tell much from the dust wake if vehicles speed is not consistant, can we ?
Right.
And for the weight thing, I guess the test would be to drive a fully loaded semi and an unloaded one side by side & compare their dust trails. I guess I'm also thinking about the tracks they leave in the dirt..... those big duals plow up a lot of dirt when they roll over it with all that weight. To me, that has to translate to much more dust in the wake. Compare it to a motorcycle going the same speed, maybe. Of course, you'll say the motorcycle has a fraction of the frontal area, too..... Hmmmm - - can we somehow load 10 tons onto a motorcycle????? or reduce the weight of said semi truck to 1000 lbs???? Maybe a strict weight vs. frontal area test would be difficult..... |
photos
The photos are great!
If wind tunnels had test sections this long and you could photograph the test vehicle at a far enough distance we'd see the same thing if smoke was introduced into the wake. This illustrates the magnitude of the wake and its relationship to fuel economy,and how an internal combustion 1987 Sunraycer would achieve 300 mpg. Hucho could use these sorts of images in his books. Thanks mucho! I would have liked to have been there.:) |
speed
The magnitude of the energy is following the square/cube relationship,so sure,the wake will be more dramatic if a Bugatti Veyron or Mike Cook's Thunderbird blows by at over 260 mph. The lake bed dust is already pulverized.And sure,if you've seen video of the Lunar Rover you know that the tires will sling dust even in a vacuum.But it is the low base pressure of the turbulent wake which allows the dust to migrate far afield of the tires 'toss' area. Ritchie Ginther's first rear spoiler was designed to prevent this 'dust' from moving forward into the cockpit of his Ferrari and killing him.It was only an accident that it also spoiled rear lift. |
4 Attachment(s)
Adding more photos. A Neon with an unusual rail across the roof: http://ecomodder.com/forum/attachmen...1&d=1384236575 A fifties coupe with that same rail across the roof: http://ecomodder.com/forum/attachmen...1&d=1384236575 The trailing razor-edge of that streamliner motorbike in my first post: http://ecomodder.com/forum/attachmen...1&d=1384236575 That thin sliver probably has a lot to do with the tiny wake left behind. Lastly, and adjustable angle trailing edge for this wing on the back of a car: http://ecomodder.com/forum/attachmen...1&d=1384237972 -james |
The rails on the roof are there to keep the airflow from rolling off to the sides and crash with the air going along the sides.
I asked the chairman of the rules committee why exactly that rule existed, and he said it was a safety thing.... If a car is going faster than 200, loses control and goes sideways, the airflow going SIDEWAYS across a car causes lift, as though the car is a blunt wing. So those two rails, which are to be as close to the edges of the roof as practical, are actually little spoilers - to kill lift in the case the car goes sideways at high speed. The alternative, as Tom Burkland, former land speed record holder, once told me, is "Taking flight without a landing plan" |
thanks for explaining that. I had just been in the rulebooks tonight and did not have an explanation yet, but the requirement for 'roof rails' was clearly defined.
Yeah, that's why we asked the rules chairman. At first, I thought it was for structural reinforcement, but when they were saying to use thin aluminum angle pop-riveted on (and that's what others were doing), it was clear that wouldn't have been much reinforcement. So, only after talking to the chief inspector/rules chairman, did we find out it was for safety in the event of a high speed sideways skid.
Interesting. Is that the first time you've gone to an LSR meet?
I like the Ferguson Racing streamliner. Anybody care to hazard a guess at its Cd? |
But then when I started seeing them, and seeing they were thin aluminum strips with almost no strength at all, I was really curious. Could they be some kind of fins to help keep the car straight at speed? Surely not. So finally I asked and was told they were basically aerodynamic "stall fences" when turned sideways to the wind. Without them, the shape of most cars is enough like a fat wing to cause it to lift off the ground at speeds over 200 mph. But those two little strips, 3/4" high, running the length of the roof along each side, are enough to break up the lift that would otherwise form. I had a similar thing explained to me about my air dam, which went almost all the way to the ground. That helps a lot when going FORWARD, I was told, but I should make provisions for it to break away or otherwise vent the air that would be trapped behind it if I ever spun out and went BACKWARDS at high speed. In that case, the air dam would catch the air and turn my car into a hovercraft!!! - Or worse. As Tom Burkland put it, "You could find yourself taking flight without a landing plan..." :eek: See, I was going around thinking this salt flats racing was the safest thing in the world; nothing to hit. But then it was explained that there IS something to hit - the ground! When these cars get to extreme speed, the danger is some aero forces lifting them into the air and then they impact the GROUND with lots of force. Guess that's what kills most Bonneville guys - and sometimes fire..... |
weight
Aerodynamic drag dominates the road load power at these racing velocities.Rolling resistance is essentially meaningless.
The weight will impact power-to-weight,so it's important to acceleration. The weight will also impact traction,as many of these cars are capable of wheel spin at over 250 mph+. Some racers add ballast to improve grip. Spins are potentially fatal.If the car goes sideways and lifts off,if it lands sideways it can dig in and barrel roll.The centrifugal forces and accelerations of the crash can easily exceed human tolerances.Only an onboard fire is worse. |
crash video
Well, he stayed right-side-up, so that's a good thing!!
I did a maneuver very similar to that at Bonneville in 2008 at 161 mph. My car stayed flat too, and I was very thankful for that! I wasn't in a cloud of dust - in my case, it was a cloud of smoke because when the engine blew, oil spewed all over all the hot parts, so it was nasty. I couldn't see anything until I came to a stop and was able to open the door. They have a rule that if you have an "emergency", to pull off onto the right side of the course (if you can). I couldn't see through the smoke, so just nudged the wheel ever so slightly to the right. As luck would have it, I ran right over the right side "2-mile" sign & timing light. I remember seeing the big orange "2" momentarily appear in the windshield. Anyway, they actually "prepare" the course by repeatedly dragging & rolling it. Off to the sides, the salt isn't nearly as flat, smooth, and hard as on the course. So I think what happened is when my right wheels hit that soft salt, it musta tugged on that side enough to upset the equalibrium. So I went into a skid, spinning to the right, & made at least a couple complete turns before finally coming to a stop. At the time, I thought it was a half dozen turns, but now I doubt it could have really been that many. The year after, my engine blew at 183 mph and there was even more smoke. But that time, I was able to exit the course to the right without spinning out, so just did a big, long arc to the right until my parachute stopped me. There was so much smoke that time, they were sure there was a fire. When the fire truck got there, they were almost insisting I "admit" to a fire & tell them where it was. We opened the hood, the trunk, & nothing was burned. But they kept holding their fire extinguishers with "hair triggers", all dissappointed not to be able to spray anything. Later, I discovered I'd forgotten to "arm" my on-board fire suppression system before taking off on that run. It's a good thing there wasn't a fire, because I'm not sure I would have had presence of mind enough to think to pull those safety pins if I'd tried to hit the extinguisher and nothing happened while bathed in flames!!! There was actually SO much smoke, I was halfway wondering if there was a fire for awhile. But I couldn't feel heat or see any orange light, sooo.... But the smoke was so thick, I was having trouble breathing and actually got just a little worried about smothering at one point! I was sure glad when I was able to release the door net & roll down the window! It was quite an adventure, I can tell you that!!! :eek: |
Dry lakebed dust on my '98 Civic
2 Attachment(s)
Last images from El Mirage.
In the first, you see the dust collected at the trailing edge of the trunk lid, where a line marks a curve downward (dust collected there fairly consistently), dust collected on the ledge just below the license plate, and lots of dust on the top of the bumper cover (but not at the ends of the cover). http://ecomodder.com/forum/attachmen...1&d=1386028292 In this second image, dust has collected on the aft side of the opening for the driver side door. It is smashed into the sheet metal and the trim, but not on the forward edge (on the door itself). http://ecomodder.com/forum/attachmen...1&d=1386028292 |
Those roof fences have been on NASCAR race cars for many years.
