EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Aero template request (https://ecomodder.com/forum/showthread.php/aero-template-request-21705.html)
2000neon 04-30-2012 11:43 PM
I really suck with computers, would anyone be able to put the aero template overlay onto a 2000 dodge neon for me? I would really appreciate it! :thumbup:
2000neon 05-02-2012 07:36 PM
Bump, anyone? I would really appreciate it
Sven7 05-02-2012 08:31 PM
http://i49.tinypic.com/v4w4ts.jpg
JethroBodine 05-02-2012 08:37 PM
Hang on a sec.
http://i1201.photobucket.com/albums/...M/neontail.jpg
Best I could do on short notice.
JethroBodine 05-02-2012 08:39 PM
D'oh! Sven, you beat me to it( and better, too:o:D).
2000neon 05-02-2012 08:47 PM
Sweet!! Thank you guys so much! Im surprised to see how close the trunk lid comes to the template line, which makes my next job a lot easier :)
2000neon 05-02-2012 08:51 PM
Is there a different scale used between the two pictures? I see the line on the second one extends farther behind the trunk lid.
Sven7 05-02-2012 09:24 PM
Mine is true scale. You can measure off it and it should be exact to the car. When planning mods it's best to have as little perspective as possible and the blueprint is perfect for that.
Your rear window is pretty darn close to template. You might consider tuft testing it first to see what's actually happening.
2000neon 05-02-2012 09:32 PM
Thats the plan, im going to try tuft testing it to see if the airflow remains attached, considering doing some coastdown testing with a decklid extension and/or roof spoiler
Sven7 05-02-2012 09:37 PM
Definitely. If you're doing coast down testing I wonder if you'd be up for a little experiment. I don't own a sedan so I can't do it :)
Search the forum for "coventry papers" and read about the "base plates". I was wondering if one could make something like that that goes vertically up from the edge of the trunk, like a Bonneville spoiler that goes up (instead of out) to meet the template. Does that make sense? The advantage would be if it were made out of plexi it would barely be visible.
I just thought if you're doing it maybe you'd be down. A suggestion :)
2000neon 05-02-2012 10:10 PM
That makes sense,I will look into that and try to figure out a good way to attach it and gibe it a try! After tufting to see what Im working with I really want to try a decklid extension.
I guess the idea of the base plate would be to "trap" a vortex to force the air to follow the template? In the theory it seems reasonable, but of course air is unpredictable. I'm sure that matching the height in the centre would be easy, determining how much to curve it down on the edges might have to be some trial and error.
Frank Lee 05-02-2012 10:34 PM
What pic are you looking at? :confused:
JethroBodine 05-03-2012 05:44 PM
My pic was a grab off the web, Svens is true to scale. I looked for a drawing but couldn't find one quickly, hence the out of perspective rendering.
I'm with Frank. I don't think you will get attached flow as the rear roofline deviates from template fairly early.
Sporty Modder 05-03-2012 06:05 PM
I belive what you are describing is considered a gurney flap named after Dan Gurney in the 60's who used it on a Le mans racer finding minimal drag with huge downforce. Correct me if I am wrong.
ChazInMT 05-04-2012 07:51 AM
http://i46.tinypic.com/ddjoud.jpg
Here's my 2¢.
You shred the air at the top of your rear window.
If you really want to improve the shape, you must follow the template with something solid, a roof spoiler or a rear deck lid extension won't do much.
The air needs to "ride down" on something in order to return its energy back to the car, by the time it hits the extension it is too late, if you cut off flow with a roof spoiler, you really aren't improving on what you already have. The current shape is not terrible, it just isn't optimal. You have to add a "Kamm" extension to optimize.
ChazInMT 05-04-2012 08:53 AM
Sorry to do this Sven, but I think you need to look closer at your template, it appears to be out of proportion with what the standard is.
Here is a small pic.
http://i49.tinypic.com/jtpf14.jpg
and a link to a more detailed one.
Big Sven 2 Templates Compared
I have been very meticulous in maintaining this exactly. On several occasions I have slipped up and forgotten to maintain the aspect ratio thereby ending up with an out of proportion image.
You can see my template on top of Phils, I have verified again before creating this image, that Phils Image is the 1.78 aft ratio. My analysis of your template is about 1.5 aft ratio. The fronts are really not too important as we know.
Charlies Template on Phils Drawing
kach22i 05-04-2012 09:12 AM
The one I've been using is a little different, but closer to Chaz's.
Automobile 2 - Odds and Ends pictures by kach22i - Photobucket
http://i184.photobucket.com/albums/x...lay-e9ep2s.jpg
botsapper 05-04-2012 01:15 PM
Some ideas from an older thread. http://ecomodder.com/forum/showthrea...tml#post217527
Sven7 05-04-2012 01:27 PM
I'm using this one. If it's wrong let me know and I'll delete it from my computer. Maybe we should sticky the Template Part C thread.
http://i48.tinypic.com/20a4h.jpg
Don't know what a Gurney flap is. Basically a spoiler?
I'm not trying to say the base plate thing would be the final product, or that it should be used. I was hoping for a little data on it to see if it would even help. It was supposed to be a research project.
Of course a Kammback/boat tail will be your best bet for drag reduction. As long as we're testing the car we might as well test alternatives based on Coventry University data to see if there are other options for those pressed for time or money.
Sporty Modder 05-04-2012 01:42 PM
Gurney flap ... Think nascar rear spoiler
Sven7 05-04-2012 02:10 PM
Similar, but shaped as if it were a section of the template teardrop in 3D. Rounded on the sides to meet the plan taper, and all that. Meant 100% for drag reduction and not necessarily downforce.
aerohead 05-04-2012 05:50 PM
Gurney flap
If you can find a photo of a 1969 Ford Torino Talladega,you'll see a Gurney flap used on this car.Very small,90-degree angle.
redorchestra 05-04-2012 08:29 PM
am i doing this right?
http://a2.sphotos.ak.fbcdn.net/hphot...45506469_n.jpg
Sven7 05-04-2012 09:44 PM
Klaatu Barada Nikto!
TOOSTUBBORN2FAIL 05-04-2012 10:00 PM
For what its worth, I did tuft testing a couple of years ago on a 1st gen neon coupe, and there was significant detachment on the rear window and trunk/factory spoiler. Anything past 1/4 the way down the window, and the tufts were facing forwards.
redorchestra 05-04-2012 10:19 PM
http://www.blainekahle.com/images/we...to_853x480.jpg
ChazInMT 05-05-2012 09:01 AM
Sven, It looks great here, just be sure when you overlay it onto stuff you don't change the aspect ratio. It appears as though you shortened it when you put it on top of the Neon is all.
Thanks for all your good works! I hope I have not dimmed your spirit in any way. You are such a valuable part of Ecomodder.
Much respect,
Charlie
aerohead 05-05-2012 01:33 PM
Originally Posted by redorchestra (Post 305255)
Looks dead on to me.Ford gave you a very nice starting point. Happy modding!:)
Sven7 05-05-2012 01:47 PM
Much respect,
Charlie
WTF I just overlayed them in Photoshop and the Neon one is indeed squished. Can't believe it. :confused: Good eye!
kach22i 05-05-2012 02:40 PM
A bunch of people in this forum got pretty picky when I made the same analogy.
See here:
http://ecomodder.com/forum/showthrea...uck-18005.html
http://i184.photobucket.com/albums/x...20Up/GUR-8.jpg
Technically speaking, a Gurney flap is on a wing (and only a wing).
Anything else is merely a rear spoiler.
If the thing looking like a Gurney flap is on the trailing edge of something looking like a wing (fiberglass trunk lid bolt-on), but there is no air flow under it, then it is a spoiler on a spoiler, not a Gurney flap.
2000neon 05-07-2012 12:25 AM
Thanks for the extra images and input! Ive been swamped working on the El Camino all weekend and totally neglected the Neon. But some test ideas are in the works already :)
