aerocap or tonneau? (build thread?)
hey all-
i've decided to make an aero...something for my frontier's bed.:thumbup: for the use of mine, mostly 45-55mph with a bit of city driving, whether a tonneau cover or a aero cap would be more beneficial. because i would love to try making an aerocap like bondo and others have, but i think that a tonneau would be a bit easier to make and if the benefits were same/similar then i'd go with that. also, wouldn't a back half-tonneau with something trailing off the back edge of the cab do the same as an aero cap?:confused: any input would be awesome |
cap vs tonneau
The aerocap,with plan taper gave me 13% at 70-mph with the T-100.A 1/2-tonneau on the same truck was good for 5%.A cab-wing/sailpanel extension of 18-22 inches,combined with the 1/2 tonneau has been shown to up mpg by 9% at 55-mph.I realized this on the T-100.Results are going to vary from truck-to-truck.-------------------------
I spent 200 man-hours on my original cap and never really finished it.You can slam a piece of primed/painted/reinforced plywood across the bed rails for durable proof of concept experiment.( house paint is ok ). |
My jerry-built fastback fairing, even thogh it is too steep (17 degrees) improved my MPG by 1.5 MPG over a flat tonneau. They do work.
If you haven't the time or skills to make an aerocap, flat tonneaus (hard or soft) are available off the shelf. In fact if you have a Ford Super Duty short bed, I'll sell you one cheap. |
I's there a specific site to coifecient (sp) drag numbers of different trucks? All if seen on wiki is .60 +or-
Check the "notes" at the bottom of the aero/rolling/power/mpg calculator, here: Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
There are a couple of sites listed. |
sorry dave, i have a nissan. and my budget is sorta tight so i can't really shell out for a off the shelf tonneau right now. my truck has the TracRac rails on them so i'm wondering how i can incorporate them into the design or whether they make my job easier or harder.
would picking up a regular bed cap and taking a sawzall to it to get it to the aero wedge shape, then taking, say.... fiberglass reinforcements and reattaching it in the aero shape be at all a simple undertaking? or is that more difficult than i think |
yeah wiki say typical truck .60
TracRac rails in use. http://www.jcwhitney.com/wcsstore/jc...1617G_CL_3.jpg TracRac rails only. http://www.jcwhitney.com/wcsstore/jc...1617G_CL_1.jpg |
oh yeah, sorry about not clarifying that, sorta figured everyone knew what they are, there's a lot of tradesmen around my area, gotten used to seeing them on every other pickup
Thats what you get listening to angry squirrels sing bad songs
