Old 09-07-2011, 02:27 AM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Grill Block Solutions for my 318iS? Inner or outer?Upper/Lower/Both?
I'm about to start modifying my BMW 318iS for better aero/lower Cd..
I've read a bit about grill blocks on here, so was thinking on starting with an upper grill block:
The carr's grills are like this
Front End[/B]
Initially I'd be concentrating on the "Kidney" grills (chrome surrounded shapes with Black vertical infills).
These lead directly to the Radiator, whick is also cooled by the lower grill and a viscous fan drawing in air to the bay.
as per the project thread for this car, I'm keen to keep the mods discrete, and reversible so my initial thoughts are
1. 2 pieces of Clear Perspex cut to size and mounted BEHIND the grills-stopping through flow to the rad
or
2. 2 pieces of Clear Perspex cut to size and mounted N FRONT OF the grills-stopping through flow to the rad
or
3. Individual perspex pieces blocking the gaps between the black vertical dividers.
What would you do?
Any suggestions as to how to mount it?
Thanks!
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 09-07-2011, 10:15 AM   #2 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I would go for the option 2 and for the attachement little bit of clear silicon. That you can scrub off if needed and the change will be invisible.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 09-07-2011, 11:04 AM   #3 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
In front of the grill will be best and Vekke using clear silicon is a great idea I will need to try that when I do the final version of my grill block.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 09-07-2011, 11:24 AM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Silicon will work perfectly if pieces are that small and almost flat. If there is lots of curvature its more difficult to clue due to tensions.
Old 09-07-2011, 04:57 PM   #5 (permalink)
Team m8
Thanks Guys!
I was thinking Silicone would help attach-and as you say, clear one would be almost invisible..
For the grill block I was going to use 2mm Perspex, a it'll allow it to bend slightly- sure I can heat it to get a gentle curve if required.
So In front is the best.. ok-time to get thinking on the botom one, asa the grill is flush with the bumper
Old 09-07-2011, 11:52 PM   #6 (permalink)
Did this with my '95 325is. Covered lower grill with black 2mm coroplast, virtually invisible to the casual observer. Not sure it helped fuel economy, though, so took it off.
