EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Aerodynamic Fairng Question (https://ecomodder.com/forum/showthread.php/aerodynamic-fairng-question-21232.html)
Mr. Previa 03-31-2012 08:24 AM
Hi All,
Aerodynamics is not my strong point, so I need some help.
As some of you know, I installed a solar panel inside the back of my 92 Geo HB. It works ok, but nothing like it did when I had it mounted on the roof rack of a previous vehicle.
I am trying to be more of aerodynamic with my little gem. I can see that if I mount the panel on the roof of the Geo, that it will essentially create an air brake. :turtle:
A fellow member and I shared the idea of incorporating the panel into a kammback, but the panel is too large.
If I add a fairing/wind deflector to the front of the solar panel, it should help considerably, right?
I was going to add flexible solar panels, but I got ripped off by a scammer in AZ when I sold him some parts. :mad: So, I have to use the large solid one I have on hand.
Any hands on experience and facts would be great.
Thanks!
aerohead 03-31-2012 04:09 PM
PV
If you're going to run it on the roof,I recommend that you soften the front and side perimeter with convex radii equal to the panel thickness,and a gentle ramp off the rear face to keep flow attached back down to the roof surface.This ramp could taper in at say 5-degrees at the sides on each side for a tiny improvement.
The sides will help in crosswinds.
drmiller100 03-31-2012 09:35 PM
mount the panel 20 degrees to horizontal, downwards at the back.
run the top of the car back to the panel at 10 to 15 degrees - keep it smooth as you can,.
Then build sides for the panels to fill from the panel down to the hatchback.
Probably does not matter what the sides look like.
