Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15%
From GCC:
skirts/boattails
Yep,it all works! And luckily for America, the DOT allows the boattails to be run on roads without special permits.I see trailer side skirts,they look like ABS,some are already fracturing,don't know the cause.With Diesel now at over $4.00/gallon,we may see more air cheaters on the road.
UV exposure makes it more brittle (I know a member here has a citicar - ask him about that :D). Given the vibration/forces a trailer side skirt would see - it's likely to fracture if it becomes too brittle. Honestly, sheet metal with folded edges (for a bit more stiffness) would be very appropriate here. Sure, it will weigh more, but longevity is key for an application like this. And besides, it doesn't have to be plate steel :p From GCC comments http://www.freightwing.com http://www.freightwing.com/Robert%2011-06%20063.jpg ^Look how this one tapers inwards too... http://www.freightwing.com/Conway-Pics-029.jpg http://www.freightwing.com/Brockway_6-5-06_041.jpg |
i saw an experimental one today!! i tried to take a pick, but it was too blurry on my phone. It was gray plastic, in 3 pieces on each side, and they had test piece #4 in the middle of each panel.
Hopefully someone will start mass producing these for cheap, so trucking companies will be more will to buy them |
Theory: Trailers are often not owned by the Owner/Operator, so the trailer owner has no interest in spending money to save the provider. As for the big trucking companies -- is it too late? Right now money's tight with the fuel price, so how much extra cash is there to retrofit trailers? It can only save in the "long-run"... RH77 |
Most businesses look at payback time on stuff like this. It didn't take very long for restaraunts to switch to CFL (for the most part) because they have 1,000 lights in their establishments. If its got a pretty quick payback time, then I see them investing in it a lot easier than if its got a 10 year payback.
And jeez, 10-15% From side skirts? Imagine an actual aerodynamic design, not a band aid. |
Considering how many dozens of thousands miles big rigs run each year, 10% on a heavy truck means way more than 20% on my little commutatruck. Imagine if we could consistently get 10 or more mpg out of a long-hauler. Trucking companies would be knocking each other down to rebuild their fleets with that model.
It would not cost very much to make light and removable plastic panels usable on most or all trailers. With these, they could fair the airflow around the leading edges, sides, bottom, rear, etc., and remove for use on other trailers at the end of the trip.
For that matter, the tractors virtually all have aero designs that really suck. What were those people thinking? |
I do agree that Class 8 trucks offer a lot of scope for fuel consumption reduction.
That said, the sheer flexibility of the “tractor-trailer arrangement” defeats any “silver bullet” anyone can come up with. There are trailers of every description and are used in a lot of different ways. Some lend themselves to improvements in FE, some are Mission: Impossible. Take the most common trailer – the box van. Actually it has two versions. One is the purpose-built box van and the other is a type of flatbed that is specialized for standardized shipping containers. A trucker may simply drive to a destination, unhitch his trailer and pickup another (very common) or he may wait at the dock for his trailer to be unloaded and maybe reloaded for another run. Where the shipper owns the trailer (FedEx, Wal-Mart) and can control the usage of the trailer, you will see aero trailers. FedEx doubles in particular are rapidly going to aero features. But when you drop a trailer and grab another, the trailer owner has zero incentive fort any frills, because he doesn’t think he pays for the fuel. On the other hand, a bulk trailer (dry stuff like flour or plastic pellets) might spend its entire service life hooked to the same tractor. But somewhere along the line somebody decided that the additional weight of fairing in a mobile adventure in piping imposed more of a weight penalty than the aero gain. The same is pretty much true of tank trucks. Old goats like me remember when truck trucks were nicely faired, but nobody has made a tank trailer like that since the 50s. Too expensive, too heavy, and the fairings tend to hide leaks. Flats and auto delivery trailers (“rolling parking lots”) are probably beyond hope. A subset of trucks that has a lot of scope for aero work is “expediters.” These are long-range (they have sleepers, road gearing and drive trains) straight trucks usually Class 5 or 6 but sometimes Class 7. These trucks generally haul light, time sensitive loads over medium distances – say Pittsburgh to Indianapolis. Time sensitivity means they have to run as fast as they can get away with and that opens the door for aero mods. The truck is all solidly attached so they tend to be owned by owner-operators and they are touchy about fuel. Trucks severely need to get into CCTV rearview systems. Class 8 trucks are often festooned with three or four sets of side-view mirrors. |
Cool
Like this!
http://www.ats-green.com/images/smarttailback.jpg
This thing gets over 5% savings and it automatically delpoys at highway speeds, and stows itself before you get to the loading dock so you can open the doors like its not even there.ATS Aerodynamic Trailer Systems - SmartTail and WindTamer products to reduce aerodynamic drag |
Cool, looks something like a hovercraft skirt.
