Old 07-14-2008, 10:32 AM   #1 (permalink)
SaturnSl1 - '00 Saturn SL1
90 day: 40.21 mpg (US)
MyPickup - '96 Ford Ranger
CRX HF - '89 Honda CRX HF
90 day: 51.59 mpg (US)
Belly Pan on the Saturn
There was a link posted a while back for an article by AutoSpeed? about installing a belly pan on the prius.
I thought I'd go ahead and try it. I didn't want to use coroplast since I don't think it holds up over time and has enough durability, so I bought some ABS plastic. Not cheap, about $2 per square foot. Made a cardboard template and simply cut it out.
It's mounted with four sheet metal screws in front and is held up with releasable zip ties in back. It takes less then 5 minutes to take off and the only thing it covers up is the fluid drain on the radiator.
So far, my perception is that it's a smoother ride, and noticably quiter on the highway. I'm thinking of doing something similar with the rear end next.
ID:	1156   Click image for larger version
Old 07-14-2008, 11:33 AM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Raysp30 -
Thanks for the pix! Did you paint it black or did it come that way? I really gotta get my act together and do this too.
CarloSW2
American Solar Energy Society
Old 07-14-2008, 11:47 AM   #3 (permalink)
It came black. One side was very smoooth, the other had a sand texture to it.
Does anyone know about the link I mentioned with the Prius? I plan on doing front wheel diffusers next. I have some styrofoam that I'm planning on shaping and then covering that with Bondo and attaching it infront of the wheels.
Old 07-14-2008, 11:47 AM   #4 (permalink)
rjacob's Avatar
2017 Honda Civic LX - '17 Honda Civic LX
90 day: 39.92 mpg (US)
Can we get some better pics please? Thanks!
GreenCarMPG.com
Old 07-14-2008, 11:57 AM   #5 (permalink)
If you're talking about the size of the picture, that was the best I could do. There was a 97 kb limit on my size.
If you're talking about not being able to see clearly, keep in mind that there wasn't much room to take a picture down there.
Old 07-14-2008, 01:08 PM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
The autospeed article info:
http://ecomodder.com/forum/showthrea...prius-587.html
You can post bigger pics. 97 kb per image. The first image you posted is smaller than 5 kb.
Old 07-14-2008, 01:17 PM   #7 (permalink)
Thanks for the link. Will be useful for the front wheel mod.
Here's the first picture a little bigger. I think I have the hang of resizing now...
Old 07-14-2008, 01:20 PM   #8 (permalink)
Okay, now both pictures are bigger.
Old 07-14-2008, 01:46 PM   #9 (permalink)
rjacob's Avatar
Thanks. The first pic looks much better. I wonder how hard it would be on my Honda. I will have to look under the car and see.
If I still lived back in Seattle, I would just go down to Boeing surplus and buy big sheets of aluminum, or heck, maybe titanium. At least they had that stuff 20 years ago.
Would still love to see more detail.
GreenCarMPG.com
crx coroplast belly pan finished! paulwelkins EcoModding Central 28 05-15-2015 05:24 AM
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 05:13 PM
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
belly pan thrash 2008 lovemysan Aerodynamics 12 09-23-2009 07:51 PM
2009 skyline belly pan pics lovemysan Aerodynamics 9 04-02-2008 05:02 PM
