Aerodynamic improvment in front of vehicle. (Tire spats/deflectors)
I think we all (with aerodynamic cars) can use whiskers like in front of Daihatsu UFE III (2005 Concept) to reduce front wheel drag.
My aero improvment will include whiskers, move side mirrors inside, wipers air deflector, a kammback. |
phord -
You mean this? : http://images.motortrend.com/auto_sh...tsu_ufe3_z.jpg I'll bet you said whisker because it has a catfish look to it. I think the proper term is "strake". Here it is on the Ford Probe IV : http://ecomodder.com/forum/member-cf...iv-strakes.jpg For me, they look like toy boat hulls, so I have kept my eye out for them in Toys R Us, ;) . CarloSW2 |
Note the goofy ferris wheel looking spokes painted on the smooth aero hubcap.
I've wondered if the whiskers that they use at the rear of RV's would work as the bottom of an air-dam in the front of a car? If they are stiff enough to push the air up and over - they are certainly flexible enough to not be damaged by scraping into driveways and bumping into parking curbs. |
Thanks, I had missed that thread.
It does seem that if you could curve a brush around the outside edge of your wheelwell, that in conjunction with a smooth hubcap could do a fair job of isolating the airflow around and inside the wheelwell. And if you had an airdam that had 5" of ground clearance and could add a 4" brush below that, your effective airdam would be within 1" of the ground, which should do a good job of keeping air from flowing under the car. Add to that some brush side skirts and things might be pretty quiet under the car. I wonder if there is a clearinghouse that has odd lengths of the stuff that they would want to get rid of for very little money? |
Nels -
A non boat-hull shape for a strake is the shape of a dust pan like this one : http://ecx.images-amazon.com/images/...500_AA280_.jpg You would want one that does *not* taper from large to small : http://www.business-supply.com/sku_i...6C0100_1_1.JPG You want it to be at right angles like the one in the first picture. CarloSW2 |
Details: The Truck (Retired) - 1999 VW A3 Jetta TDI Fuel Economy - EcoModder.com EcoModder Takes Home Four Awards at the AMEC Fuel Economy Run | Hypermiling, Fuel Economy, and EcoModding News - EcoModder.com |
active-suspension?
Does the UFE have active-suspension? It looks like the "whiskers" would be knocked off on driveway ramps,sidewalk curbs, and parking barriers.
