Old 11-08-2016, 11:20 AM   #1 (permalink)
Automatically actuated grill block - Mk3
So, I've tried this before, and each time its become a pain in the butt in some way. This isn't abnormal in the product development process, so we keep refining the design until we come up with something better that works and meets all the design criteria. For kicks, lets go over the past designs.
The first automatically actuated grill block was extremely simple in design, but not structurally strong enough. It was made mostly of coroplast and when installed on the car it flexed too much. All of the flexing essentially eliminated the ~1" throw of the actuator I was using.
The second design was a lot more rigid, and designed with scalability in mind. It had an aluminum frame, with coroplast blades that had steel rods in them for reinforcement and pivoting on. However, it ended up being a pain to make and put together. It was quite time intensive building it, and it still had its issues with the pushrod setup binding.
This brings us to the Mk3 design. This version is also designed with scalability in mind, and the frame is also quite rigid. However, I didn't want to spend time building it, so much so that I don't even want to use tools to assemble it. So, this grill block is going to completely snap together. Sounds lazy eh? Sounds brilliant to me. So, I'm posting what I have thus far. Darin has been bugging me for a few days now to start a thread about it since I started telling him about it. It is not complete, but it is a fair ways along. The design is nearly 100% 3d printed. The actuator will bolt to the assembly of 3d printed stuff and you'll probably need a pushrod or two to finish things off. That is the hope at least.
This design is primarily made for my 2000 Honda Insight. It has a very short lower grill. The opening is only 3" tall, so I only needed a single blade. The grill block when open is currently shown as 2" x 6". I'll probably end up making it a bit longer, but its about as tall as it is going to get.
Here is the blade. You can see its made of 3 pieces. If I need to make it longer, I can make the pieces longer, or add additional pieces that snap together between the end pieces. I've printed these pieces and tested out the snap fit and its surprisingly strong.
Here is the frame. I have not been able to print and test these snap fittings yet. They're very similar in design to the blades though and I'm pretty sure they'll be fairly strong. If not, they can be tweaked.
Here is the assembly as far as I have it so far. The blades fit into the slots on the frame, and there is another clip that holds the blade in. It is 100% snap together.
The next step is designing the mount for the actuator (a power door lock actuator), and developing the linkages between it and the blade. I already have some ideas, I just need to model them up. I'll be updating this thread as I get more designed.
As always, I'm open to ideas and feedback that you guys have.
ID:	20871   Click image for larger version
ID:	20872   Click image for larger version
ID:	20873   Click image for larger version
The Following 7 Users Say Thank You to Daox For This Useful Post:
aerohead (11-12-2016), BamZipPow (11-08-2016), IamIan (11-20-2016), Leinaad (08-16-2018), NeilBlanchard (05-15-2017), WD40 (11-08-2016), Xist (11-09-2016)
Old 11-08-2016, 11:51 AM   #2 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
Dang! That's pretty neat! Keep up progress, I need one soon.
Old 11-08-2016, 01:42 PM   #3 (permalink)
90 day: 40.51 mpg (US)
Take my money.
Old 11-08-2016, 02:08 PM   #4 (permalink)
Hah, I figured the Insight guys would like it. If it works out well, I hope to redesign it for the Prius as well. It would be even more useful on that vehicle as it warms up slower than the Insight.
The Following User Says Thank You to Daox For This Useful Post:
Old 11-08-2016, 04:45 PM   #5 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I'd like one on the Leaf, I'd say that I also want on in the TDI, but at 1.5 tanks / year I can no longer justify modifying it.
Subscribed:
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 11-08-2016, 05:36 PM   #6 (permalink)
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
Nice work, make one for my GEO so I can do away with the chaps & spikes look... !
Old 11-08-2016, 08:59 PM   #7 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
Where do I sign up for one? lol
2000 Insight MT 106K Citrus A/C
Old 11-08-2016, 09:47 PM   #8 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
http://ecomodder.com/forum/showthrea...ers-31585.html
Want to buy my prototype? Been hanging in the garage since graduation. Worked on the bench but never put it in a vehicle.
Old 11-09-2016, 09:53 AM   #9 (permalink)
...beats walking...
Doax, you might want to "design-in" a steel rod *inside* the two pivots rods, or alternatively slide a metal bushing over them to both reduce rotating friction and provide physical strength.
The Following User Says Thank You to gone-ot For This Useful Post:
Daox (11-09-2016)
Old 11-09-2016, 10:25 AM   #10 (permalink)
Interesting idea Old Tele man. I do want to keep the design as close to 100% 3d printable as possible. I don't think friction will be an issue. The blades are very light weight, and all the joints are designed with a bit of play in them. Those power door lock actuators also have quite a bit of oomph. I do like the idea about increasing the pin diameter to strengthen it. I had considered it, but I'd like to try it out as is first. If I increase the pin diameter it'll make the blades slightly unbalanced due to how they have to be printed on the machine.
Another great thing about this multi-piece design is if I do need to increase the pin diameter or make any other changes, I just reprint those end pieces, unsnap old pieces, and snap the new pieces together and bingo done. No rebuilding the entire grill block.
