The aerodynamics program
3 Attachment(s)
Hey, what is that program you guys use to see the aerodynamics on the car? *Look at picture*
At Discount Tire, Custom Wheels, Truck & Car Rims | Discount Tire if you scroll to the bottom it has a place to look at your car with different rims with different sizes, you can pick your exact car and what color. It could possibly be good for a perfectly side view of your car for this program... Under are some pics of what they give you. http://ecomodder.com/forum/attachmen...1&d=1248474254 http://ecomodder.com/forum/attachmen...1&d=1248474254 http://ecomodder.com/forum/attachmen...1&d=1248474254 |
RandomFact314 -
I've done the same with tirerack.com car pictures. I agree that these are excellent side views of your car. However, the flow illustrator program has limited computing capacity, so you should "downgrade" the image to be a black and white pixel silhouette at 256x128 pixels. Here is a 1989 CRX from tirerack : http://ecomodder.com/forum/member-cf...e-tirerack.jpg After lots of massaging steps, I get this : http://ecomodder.com/forum/member-cf...hite-image.gif The above image is a GIF for viewing on this thread, but it should be submitted as a Windows Bitmap to the flow illustrator program. This picture is in reference to this thread : http://ecomodder.com/forum/showthrea...ator-3709.html CarloSW2 |
