Old 04-15-2008, 05:08 PM   #1 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
rear taper distance?
If I were to taper the back of my Jetta sedan at the ten degrees and then terminate it kamback style, what would be a good distance to measure back from the decklid to stop. I figure I'm tapering about 2 inches in for every foot I go back and the narrowist point of the car is 4 feet wide. It would take more than ten feet to fully taper if it was straight and not elliptical. If it were to be elliptical what formula could I use to get a good long axis oval taper? It would be constructed with coroplast.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 04-15-2008, 06:10 PM   #2 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
Hi and welcome!
It should be as long as you are willing to make it. The Cd of the vehicle depending on the boat tail lenght follows a logarithmic function.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-16-2008, 10:41 AM   #3 (permalink)
Tinkerer
kafer65's Avatar
Team Mazda
Without any curvature and I stop at four feet back I get a pretty good result. The kammback would be about two feet wide and a little more than a foot tall. I just don't want to get too strong of a tapper and loose the benefits. Thinking about mounting the framing to a bike rack for ease of removal.
Old 04-17-2008, 12:38 PM   #4 (permalink)
boattail
kafer,if you will GOOGLE maxmpg ,go to that site, join if you are not a member,and then go to the PHOTOS section,under MISC. I've got 222 aero photos over there.Photo HPIM0248 shows Mair's boattail research graphics,and HPIM0222 shows an ideal aero form with proper boattailed back.Your Jetta begins it's body taper close to the B-pillar I believe,for both the roofline,and body sides.If you have photographs of your car you could photo=copy that onto a larger sheet of paper,mark your theoretical terminus at ground level ( approximately 4 body heights behind the point where the body begins to taper(,then take a French-curve to draft the elliptical line from the Jetta's roofline to the terminus.Blow this image up as much as you like to take scale measurements of,for the layout of your project.Once you have a few data points in full-scale,you can use a 20-foot length of 1-inch,schedule-40 PVC pipe to use as a huge French-curve,to establish your full-scale layout.Should the projected lines from the sides differ from that of the roof,you'll have to integrate that into the design.As already mentioned by other members,performance of the tail will vary with length.Weigh out conflicting parameters and compromise at some arbitrary length.Safety is PARAMOUNT! Since you will effectively be attaching a weather-vane to your car,you must honor what has been established empirically to be safe,mainly,generous upper corner radii,which increase in radius,as the tail projects rearward.These curved corners will help local pressure differentials to bleed off and frustrate potential yawing moments,notorius in early long-tail cars.Your center of pressure should end up behind your CG and at speed the car should exhibit over-steer if anything,with which most drivers are comfortable.Don't go crazy with length,as you may start knocking into stuff when rounding corners.
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
Video: tuft testing (rear) 1993 Ford Mustang notchback MetroMPG Aerodynamics 12 02-05-2011 09:40 AM
rear diffuser fabrio. Aerodynamics 30 05-17-2010 12:36 AM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 12:01 PM
Rear window fairing (roof extension) apgrok1 Aerodynamics 14 03-12-2008 12:33 AM
