EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Aeroflexible Aerodynamics (https://ecomodder.com/forum/showthread.php/aeroflexible-aerodynamics-27250.html)
botsapper 10-11-2013 01:49 PM
An intriguing and inspired natural mimicry from birds and feathers. Maybe separation concerns could be addressed by your own ubiquitous tufts/flexible flaps... http://www.youtube.com/watch?v=Nbk8zSRCytA[/url]
A longer presentation. http://www.youtube.com/watch?v=Fp1HFrDlRVY[/url]
cptsideways 10-11-2013 03:48 PM
Interesting, though not a new idea something similar has been seen before I'll see if I can dig up a link.
kach22i 10-11-2013 04:10 PM
You mean the Wright Brothers were on to something?;)
wing warping demonstrated by park ranger at Wright Brothers National Memorial
http://www.youtube.com/watch?v=KMDilr110XQ
<iframe width="560" height="315" src="//www.youtube.com/embed/KMDilr110XQ" frameborder="0" allowfullscreen></iframe>
Actually these fake feather things are the next step past the Wright Brothers.
I wonder what took us so long?:confused:
RC Model Version.
Wing Warp Electric RC Plane
http://www.youtube.com/watch?v=ljRgzcvhE7M
<iframe width="420" height="315" src="//www.youtube.com/embed/ljRgzcvhE7M" frameborder="0" allowfullscreen></iframe>
A Warped Experiment
http://www.wright-brothers.org/Histo..._Pettigrew.jpg
I think that the some of the larger flapping wing RC models use the wing warping technique to fly and control the flight.
This extended vortex version as seen in the first video in this thread could be something new, I'm not sure though. Are they claiming it as something new?
NASA website is down because of the government shutdown. Maybe they will have something on this topic once that nonsense is over.
aerohead 10-11-2013 04:47 PM
mimicry
If you'll go to PBS.ORG you should be able to watch 'Raptor Force' online.
They get into active wing warping.
The raptors can probably 'feel' the onset of stall trough their feathers follicles,and morph the wing and tail in real-time to compensate.They'd just feel it.
Testing and simulations will eventually create the lookup menus the flight control computer will use to keep the control surfaces in the sweet spot for any given flight scenario sensed by the pilots potentiometer and strain gauge inputs.
t vago 10-11-2013 04:53 PM
Gotta wonder why NASA decided to shut everything down, like they did. EPA's website simply has a little thingy at the top of their pages, stating that their website will not be updated as a result of the shutdown.
aerohead 10-11-2013 05:00 PM
mimicry
I couldn't get the computer to accept my reply above,so I'll try here:
At PBS.Org you should be able to view NOVA's 'Raptor Force' online.
There's a segment in the wind tunnel where NASA is experimenting with wing morphing.
Flakbadger 10-11-2013 05:04 PM
Fascinating video, but I have to say that birds are limited in the speed at which they can fly---With a few exception (like falcons), they do not travel past 100 miles per hour. Birds that do (again, falcons) have stiffer feathers on many of the wing surfaces.
Airplanes can and do, quite regularly, fly at high speed. The bird's wing is more efficient in many ways, and lots of small flaps (or feathers) will regulate its stability, but it seems likely to me that it wouldn't be as effective at high speed or might even be detrimental.
My "logic" is that if you coated the back surface of a car with flaps, they would create small vortices that would add up to a very large drag coefficient. Am I wrong?
aerohead 10-11-2013 06:26 PM
vorticity
Vorticity is circulation and circulation costs more than laminar flow.So yes,it would be a penalty.Someone would have to finance a study to actually quantify the magnitude of the loss.
Gentoo penguins have been measured at Cd 0.07.If they were 'sanded down' and covered in a smooth painted automotive finish,they might measure Cd 0.04.
some_other_dave 10-11-2013 06:47 PM
From the first video, it mostly looks like he has succeeded in reducing the amount of lift that the wings generate?
-soD
euromodder 10-11-2013 06:53 PM
So ... birds use Coanda in order not to stall out.
At speed, the feathers would remain flush.
They lift as AoA increases, like a spoiler dumping lift, lowering AoA again before it gets out of hand (i.e. stalls out).
aerohead 10-12-2013 01:38 PM
lift
I believe that as the angle of attack reaches burble point the feathers are lifted into the low pressure of the turbulence.
Depending upon the birds intentions it can deploy its tail feathers and land on something,or it can morph to decrease the AOA,restoring a 'clean' configuration.
Or,as with the Peregrine falcon,it can tuck everything in close to its body and bound towards Earth at over 200 mph in its stoop.
botsapper 10-12-2013 02:24 PM
Even though bird wings do wing warp, the inspired nature of aeroflexible aerodynamics post - is more of the contribution of the flexible 'feathers' or shown acetate flaps on a RIGID airfoil that instantaneously and self-deploys (in localized/smaller separation zones) to create more drag at high angles of attack, lessening large stall dynamics. As in peregrine falcons, the drag is kept minimal as the flaps/feathers are kept tight to their rigid bodies.
...not exactly relevant to aeroflexible aerodynamics but more on self deploying flaps. http://www.youtube.com/watch?v=uwID6XZ9UY8
Jasen 10-12-2013 03:25 PM
Interesting.
The thing that comes to my mind other then flight and driving are similar in there aerodynamics yet also have there unique caricaturists, birds wings are a in part, a manually controlled/reactive system.
There are some cars with active aero systems, but othere then an automatically lowering air damn and or suspension, most are to increase down force at the rear or a specific corner of the vehicle.
redpoint5 10-12-2013 08:34 PM
The video showed how the "feathers" allowed a natural dynamic stabilization to flight, but mentioned nothing about efficiency, or if it could decrease energy use.
I've seen flaps on the tops of the wings of various commercial jets that seem to react in a similar manner when turbulent air is encountered. I wonder if those are just large "feathers" and not actively controlled?
