EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Aeromods for Jeep Wrangler (https://ecomodder.com/forum/showthread.php/aeromods-jeep-wrangler-9116.html)
bombloader 07-05-2009 04:34 PM
5 Attachment(s)
Ok here is the aerodynamic mess:
A few things I've considered for it: A belly pan or air dam. Looking at the underside, it seems like a full belly pan would be difficult to fabricate and also might cut into ground clearance(Unlike some people, I actually bought a Jeep to take it off road.) Especially since I would have to cover up the axles to make it really effective. Air dam has even more off a problem with ground clearance, unless I could rig to be easily removable for off road driving. I know putting the top on would improve things, but I like it this way in the summer:) I've also considered a Kammback for when the top is on, since the rear of the vehicle is extremely flat. Downside-if I understand what I've read here, Kammbacks only help if the airflow is fairly attached at the back. As you can see, the nose is very blunt and the windshield is flat and steep, so the airflow may not attach to the roof. Anyway I could test this before I start rigging up a Kammback? I have used a grill block with modest improvements, however, I don't want to keep it on in the summer because of the heat. Also, I'm a little short on money right now, so I'd like to avoid really expensive projects that may give me little or now mileage improvement.
sn0w3n 07-05-2009 05:44 PM
one, buy 4 (5 if you want to cover the spare) pizza tins and usa these to cover wheels. Could fall off in havey mud or water, but by attaching with tape this should be very easy. two cant those things windows fold falt? If so, DO WHEN POSSIBLE. Most of your drag is that brick like window. 3 if your good with lezan or cholorplast try to seal the gap between bumper and fenders. (could be done with duct tape :]). that must let alot of air into an already turbulent section of the vehicle. You also might want to boat tail the fenders and if possible make fender skirts. GODD luck!
99LeCouch 07-05-2009 07:55 PM
Could try a giant airdam in the front to divert air away from the underside. This could be fabbed from cardboard and duct tape for proof-of-concept.
Frank Lee 07-05-2009 08:30 PM
I think it's pretty much futile on that thing unless you go radical; then you may find it's no longer suitable for it's intended purpose.
wdb 07-05-2009 09:59 PM
Fold down the windshield!
pvan93 07-05-2009 10:34 PM
Hi, your car has the aerodynamics of a brick. Enjoy. Embrace it. (I love my bread truck, really) You might try building a one off cargo trailer to act as a boat tail trailer for long trips. No one has to know that the rear top and sides dimensions conform to the critical 10-12 degree angle. I've just started on mine. For city traffic, nothing going to help
bombloader 07-06-2009 12:19 AM
Pvan93-
Is their a thread for your trailer on this website? I'd like to look at it if their is. That's a great idea to combine practicality and aeromods.
sn0w3n-
I'll check state law for folding down the windshield. Already planning on developing smooth wheel covers. Looked over the thread on smooth wheel covers for the S10. Would want to make sure there easily removable to get to the valve stems.
FastPlastic 07-06-2009 03:55 AM
The way I look at it is, you're already at the bottom of the hill with one of those, so the only way you can go is up:thumbup:
If you don't mind the look go for the wheel covers. Plus I'm guessing with the big tires those have finding a way to push more of the air around them would also help. I found with the Cherokee pushing the air down under more at the front helped a lot. It tends to keep the air from hitting all the nooks and crannies of the under body. The air dam I set up hangs down a little above the bottom of the front axle, so I still have a fair amount of ground clearance, not to mention it only takes about 10min to take off. I know the full belly pan would be awesome, but fair gains can also be had with a separated panel setup.
Frank Lee 07-06-2009 02:44 PM
"I found with the Cherokee pushing the air down under more at the front helped a lot."
Can't tell any such thing by the gas log. :confused:
FastPlastic 07-06-2009 05:16 PM
Oh Frank, Ye of little faith. If you we looking for a big spike in the MPG's around when I put it on you won't find much. I don't do enough highway driving to really show anything like that. But if you noticed the 24.22MPG trip, that was with a few grill blocks and the airdam plus a single under body panel. That was with normal driving. No P&G or engine off coasting. Which I don't think is too bad for a Jeep rated at 19MPG's highway.
Just remember with the super low MPG's that some of these get even a 1/2MPG can be a savings of several dollars at the pump.
sn0w3n 07-06-2009 05:31 PM
fender skirts or if not possible for clearance issues, partial fender skirts would be majorly beneficial on a vehicle like this
bombloader 07-06-2009 05:36 PM
Don't want to sound like its pile on fastplastic day, but did you A-B-A test your belly pan ever? I mean that is over 25% improvement over EPA with just that mod! That does seem a bit high. I understand the whole city mileage thing, it holds my mileage down quite a bit. I bet I do about the same percentage of city mileage as you.
FastPlastic 07-06-2009 06:08 PM
No I can't say I've really had time to try the A-B-A testing. I have a few more mods then that at this point. Listed below
  1. Grill Blocks - 4 in the summer
  2. Slanted front air dam
  3. Transmission under body cover
  4. Transfer case cover extending back about 3-feet.
  5. Roof rack delete
  6. Several much smaller panels under body - One is only 2" square
  7. Front fender gaps filled
I've also found adding a bottle of Iso-Heet really makes a difference on my Jeep. I read somewhere that the computers on the Jeeps can be tricked with stuff like that.
The reason it says 21% above is because I used the EPA calculator to adjust for the fact that I was only doing about 20% of my driving on the highway each year. So I think it quoted me 14MPG's for the average. Which is about what I was getting average before I joined this group. I need to run the numbers again and see where I'm at these days. I know I've been taking the highway more across town (like a good ecomodder should) and have gone on a few long trips as well. But it's not unusual for me to push 20MPG's all in town on my way home from work at night.
Frank Lee 07-06-2009 06:08 PM
I sincerely doubt it.
aerohead 07-07-2009 04:18 PM
boat tail trailer
pvan93, please keep us up-dated on your trailer progress.I too am fabricating such a contraption for a West-Coast test trip in September.
sn0w3n 07-07-2009 09:06 PM
why, I thought that was like one of the first mods people did to these cars.
Frank Lee 07-08-2009 01:39 AM
Have they been majorly beneficial for anyone?
Jeeps look like they're air's worst enemy from bumper to bumper, top to bottom. I suspect minor tweaks won't even show up on the radar.
FastPlastic 07-08-2009 08:19 PM
I say have at it with some card board and duct tape. The worst you could do is be out $4 for a roll of tape.
sn0w3n 07-10-2009 09:47 PM
alright bad wording then
winkosmosis 07-10-2009 11:50 PM
Drive with the windshield down. You should probably wear goggles
winkosmosis 07-10-2009 11:52 PM
Or how about slanting and chopping your windshield?
Jeep Lower Forty — Autoblog
http://www.caranddriver.com/var/ezwe...mage_large.jpg
DonR 07-13-2009 01:56 PM
Driving on public roads with the windshield down is illegal in most states.
