Old 11-30-2007, 01:24 AM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
DIY - Black Trim Painting
So, guess who's painting all his trim? This is mainly a DIY for my site but I like to post my stuff up here since this is where I got my start writing DIYs, , nothing to do with FE of course.
Anyway, it's unfinished, but big, so working in parts!
Before shot:
Before bumper:
Using two or three cans of this for the whole deal:
Piece of coroplast over a trashcan in the garage, my painting center:
An MID picture in here for no reason, that comes out to ~52 mpg for a 3 mile cold start, not bad:
Start by taking the two screws that hold the corner lights in and taking the lights out:
Make sure to store everything nicely:
Tools needed, that socket is a 10mm:
Take these two out on each side:
And this one on the bottom, this will allow you to remove the t-bar:
Get these two bolts gone:
Two of these on each side come out, might have to move the wheel a bit:
Two of these corner jobs:
Move the t-bar to expose these three things:
Start pulling the bumper off and unplug the bumper lights:
But it somewhere not scratchy:
To get at the fenders undo these two:
These three up top:
This one in the crack. Use an open-ended wrench and open the door, stand outside and reach over and do it from the crack, you'll see what I mean:
Get these screws on that bottom trim piece:
The bolt on the bottom as well:
When it's off hit up these two last bolts for the fender:
Get bored and work on this piece of trim instead:
Blast it with the hose, the suds, the hose:
Then clean it with alcohol and let it dry:
Here it is drying:
Work on the rocker panel while it dies, these plastic screws suck, you need to be very careful, especially with the ones that are more exposed:
Yay, I stripped one:
Grabbed the edge with some pliers and turned it out like that. I always leave the last few threads in the thing and use them to pull the whole thing out as one:
Some more up top:
Even more up top:
Now, get bored of that and work in the other piece that on the door. Take off this 10mm plastic nut:
This is how it clips in along the bottom, the first task is to unclip:
Half unclipped first:
Go ahead and fully unclip and then push up to get it off the metal rail:
Get bored again and decide to finish the fender, undo all the plasticy junk in the wheel well:
Fender out:
Flip it over to expose the two clips for the trim piece, pop them with some pliers:
Yay, it's so pretty:
Hit that first piece with some paint, drying at this point:
Not that this is a vertical line spray, you need to hold the can vertical to keep it going and work in a smooth, sweeping motion:
With time, there will be more.
Old 12-29-2007, 11:02 AM   #2 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
those plastic retainers w/ small plastic screw in the middle can be removed veerryy easily with a small pointed pick. Put the point of the pick into the screw portion just under the head where it meets the wide part of the body and pry gently. a screwdriver will tear them up in a heartbeat, once the head is out 4 or 5 threads just pull like you were. whole retainer comes out and is re-usable. BUT if you accidentally destroy one they are available on NAPA.com i believe they were 10 in pack for $5. S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 12-29-2007, 12:01 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
That's for the tip! I never even though of buying more,
I'll have to get a pick at some point, too.
Old 12-29-2007, 12:34 PM   #4 (permalink)
I didn't think about buying them until i need quite a few for my interior. My local Chevy dealer wanted $1.5 (approx, my memory is fading) for a two pack. Google here i come. lo and behold it led me straight to NAPA. S.
Albert Einstein
Old 12-29-2007, 01:25 PM   #5 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
Which is why I don't like going to a dealer for parts because everything costs 3 times as much as you can buy it across the street!!!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 11-20-2008, 11:10 AM   #6 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Is that a texture paint?
Because I've been considering how to finish my JettKamm - and I'm thinking of a black texture - like die injected plastic trim bits. Will hide imperfections, give it a "stock" look and is generally easy to apply.
Or I might buy my father (who does finishing professionally) a throw away gun and see about painting it with glossy black epoxy paint
And omg picture overload!
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 12-13-2008, 04:39 AM   #7 (permalink)
Hi, I am a 24 years old. I am currently taking a beginners painting class, and I am also an art major. I seem to always fall under the same style of painting, mostly impasto impressionism. I would really like to break away from this style. I thought about doing my next assignment based on a portrait with best technique, but I am afraid on how to begin with this and what sort of brushes I should use. Any helpful recommend will be greatly appreciated.
canvas photo
Old 12-13-2008, 12:09 PM   #8 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Hi, I love tomato bisque soup and I'm wondering if you have any suggestions on how to make my spackle taste more like tomato bisque soup. Right now I have a lovely bunch of coconuts sitting in a row; large ones, small ones, some as big as your head. But, yes, we have no bananas today.
Seriously?
Nice thorough work so far SVO
Old 12-13-2008, 10:59 PM   #9 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Seriously?
Usually, ROFL is an exaggeration...
I apparently need to move to warmer climes; it looks warm there with green grass and no socks/shoes on 11/30...
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 12-13-2008, 11:30 PM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
I am also confused.
