EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   air circulation button vs mpg (https://ecomodder.com/forum/showthread.php/air-circulation-button-vs-mpg-30756.html)
j12piprius 12-25-2014 12:14 AM
The air circulation button was mistakenly on throughout a recent trip.
How much difference might it have made in the mpg?
2000mc 12-25-2014 02:33 AM
Seems like it would make the car a hair more aero... I'm thinking a solid 0.00938% improvement at a given fan speed, assuming that setting did not also automaticly allow the a/c. However, if you would have been able to select a lower fan speed due to the passive flow, when on a vent setting, I'm thinking you're losing out by.... however much power it takes to spin the fan at one level higher... maybe 0.05% loss.
j12piprius 12-25-2014 12:26 PM
The circulation fan would take some energy, and the alternator appeared to be charging the battery the whole trip, even though it already had a full charge from the start. I don't use a/c, and would have noticed if it had been on.
cRiPpLe_rOoStEr 12-26-2014 12:36 PM
It may have a nearly-zero impact on fuel-efficiency anyway.
