EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Air dam and grill block (https://ecomodder.com/forum/showthread.php/air-dam-grill-block-13112.html)
Gasoline Fumes 05-02-2010 02:37 AM
I made an air dam and a grill block. The air dam is simply another bumper cover cut down and flipped over. Does it look effective? And the grill block is cut out of a Metro interior piece. Neither have been tested.
http://img.photobucket.com/albums/09.../aerowagon.jpg
wyatt 05-02-2010 02:52 AM
It looks pretty good, the bits hanging down in front of the tires are where the gains will more than likely come from. Hopefully you made the grill block easy to work on, since you could wind up needing to at some point. With mine, I remove part of it during the summer and put it back in for winter. I would either remove the wiry parts in the center or attach some more of your grill block material to it to help lower the dam some more. I can't say whether the wiry parts help or hurt, but they just look like bits hanging in the wind. Are you going to do any testing on them? Let us know how they work out.
lunarhighway 05-02-2010 05:23 AM
that looks very effective and at the same time pretty cool and stock like. i'd say what's left over of the grill is likely not needed, but on the other hand it does lools nice, and it'll allow you to experiment with a small aditional block to see if it's better open or closed.
thumbs up
jime57 05-02-2010 06:40 AM
I agree with the others. You should cover the left over grill pieces, perhaps in back with a piece of black coroplast. That would retain the look, which is very nice.
While on coroplast, I'd be very tempted to add a flat coroplast sheet across the bottom of the spoiler reaching back to the oil pan. That would smooth things out considerably on the underside. Leave a bit, an inch or so, of the flat sheet to protrude in front of the botton spoiler edge. I'm seeing this little splitter more and more on race cars. I think it might help keep a bit of air from getting under the car.
Very nice discovery. You have a good eye!
Gasoline Fumes 05-03-2010 01:32 PM
The grill block is only held in by four screws. And they're not even though it, just clamping it down. So I could probably rip it off without tools if I really needed to. But the slot between the hood and bumper is still open and there are two little openings in the slot on the bumper cover. I'm hoping that will be enough airflow. It has been so far, but Honda didn't give this car a real temp gauge, more like a 3-position idiot light. I should probably install an idiot light for the radiator fan.
I haven't decided what to do with the center of the dam yet. I thought about covering the bottom of the dam with coroplast or similar, but I'm not sure how long it would last. I scraped it once already.
What's the best testing method? I did actually try testing the grill block by coasting down a hill from a standstill, but the results were inconclusive. I was only hitting a peak of 48 MPH, I don't think it was fast enough to see a difference. I don't have anything fancier than a stopwatch for testing. How accurate is timing a high-speed coastdown? Maybe 70-50 MPH?
COcyclist 05-03-2010 03:21 PM
On the coast down testing, the higher speed 70-50 mph runs should be accurate enough to tell if it's helping or hurting. If you have a GPS and a passenger with a stopwatch, you can eliminate some of the human error. Try to do it on a calm day, in both directions on the same stretch of road and A-B-A runs if possible.
As for the scraping, in my experience the corners of the airdam scrape the most. Hopefully the bumper skin is flexible enough to bounce back. I agree that you may want to try a partial belly pan in the future. Very clever flip/flop air dam.
AeroModder 05-03-2010 03:24 PM
For coast testing, I'd measure distance rather than speed.
Gasoline Fumes 05-15-2010 02:32 AM
Grill block is out for now. I'll have to modify it or make another one for warm weather. I installed a light connected to the radiator fan and it was cycling on and off while driving. The useless temp gauge didn't tell me anything.
wyatt 05-15-2010 09:48 AM
How did you install your fan light? Is it just an LED and some wiring, or did you put a resistor in line? A wiring diagram would be helpful for those of us not too electrically inclined. Thanks.
robchalmers 05-15-2010 09:56 AM
I'd mount your auxiliary lights in the bumper and add a flat bottom and wheel deflectors to the underside. A part from that it looks very cool, i love the idea of flipping a seconder bumper!
Gasoline Fumes 05-17-2010 10:15 AM
It's a "ghetto" temporary install. Just a small bulb on the floor. I hooked it up to the fan relay.
The best/easiest way to do it would be to get a second set of radiator fan plugs from a junk car and make a short harness that would plug in between the car's wiring harness and the fan. You can then splice into the short harness for the fan light without cutting up any of your car's wiring. Or you can just splice directly into the fan wires. Use waterproof connectors to avoid corrosion. You really only need to run one wire from the fan to the light if you figure out which one is switched. But it's a lot easier to just run two wires from both fan wires to your light. Almost any wire will do. Something already paired together would be nice. Speaker wire or an old extension/power cord is fine. Just route it so that it won't get caught in any moving parts or pinched, cut, etc. Use cable ties or electrical tape to keep the wires from moving around. And when you route the wire through the firewall, make sure you protect the wire from the sharp metal edges of the firewall. You might get lucky and be able to squeeze the wires into an existing wiring grommet. If not, drill a hole after carefully checking both sides of the firewall for any important parts you don't want to drill holes into. Then install a rubber grommet to protect your wires.
A small 12 volt bulb like what's used in dash lights or parking lights will work. But be careful where you put it, they can get hot and melt plastic or carpet if they're touching it. Or you can use an LED. Most LEDs are not designed for 12 volt use, so they will need a resistor. I think something like 330 ohms or slightly higher will work. Or you can look for an LED that's prewired for 12 volt use.
busypaws 06-24-2010 08:46 PM
I found the fan relay. Then just removed the relay put a small 18 guage wire in the socked and then plugged the relay back in. So now relay is holding the wire. Couldn't find a cheap LED at PEPboys so bought a switch with an LED light. So now light comes on when fan is on and switch doesn't do anything.
lunarhighway 06-25-2010 03:34 AM
just about anything electronic has leds in it today, and usually they survive when the thing there in is junked for whatever reason. leds do need a resistor in series with them or they'll burn trough, but chances are you can find those too along with your donor led (560 ohm should be ok for 12V) perhaps someone you know has an old computer they're putting out with the trash (the keyboard usually has a few leds as might the power switch)
Gasoline Fumes 06-26-2010 05:28 AM
I changed it to this grill block:
http://img.photobucket.com/albums/09...s/newblock.jpg
I left the top of the grill open, but it wasn't enough air. So I ended up cutting out one side a little more. Now the fan only comes on at low speeds in hot weather, which it also does with no grill block. It's made from some kind of thick tar-like sheet. Not ideal, but it's flexible and I had it already.
