Airbus and Rolls-Royce hit eject on hybrid-electric airliner testbed
I can't find a good aircraft thread to drop this in. www.theregister.co.uk: Airbus and Rolls-Royce hit eject on hybrid-electric airliner testbed after E-Fan X project fails to get off the ground
After watching some videos of small aircraft fitted with Corolla engines, it seems like trying a similar approach with a Prius engine wouldn't be impossible. But anyway, I'd only hold my breath for hybrid aircraft to become mainstream as long as they're fitted with a propeller (either piston-engined or turboprop), or the fan is so massive that it requires a reduction gearbox in order to prevent the tips of the blades to break the barrier of sound.
This is only hybrid for test purposes, working toward an all-electric solution.
They flew into an airport they can't fly out of again without the un-tested 4th engine. |
cRiPpLe_rOoStEr — Didn't you talk about putting windpower in your grandmother's house? I can't find the thread. :confused:
Anyway I posted something about tuned mass dampers and now it looks like Julian Edgar predicted the future, unless it was more than a week ago. https://www.youtube.com/watch?v=FPT9dPE4oRs |
They can fly it out when the temp drops some. There's a problem with the balanced field calculation and they can't dump fuel load.
Thanks. Good that we're not headed into Summer? :)
I should have focused on the 'beer-keg' sized generator. It came across as negative. |
I won't hold my breath for some all-electric aircraft. Pressurizing the cabin with an electric compressor might spend too much more energy than it would be worth bleeding from a compressor of an engine.
Let's do the time-warp again? :confused:
thinks outside the box answer: Air can be stored quite effectively in bottles when the ICE is running |
I made housings for the shuttle high-pressure fuel turbopumps at my first job out of school. 71,140 hp shaft horsepower from a pump a little bigger than a Chevy big block. Crazy stuff.
I got to work on the F-22, F-35 and some cool DARPA stuff too: https://upload.wikimedia.org/wikiped...0295-05%29.jpg |
I dunno, seal it up pretty good, and use a submarine system to remove C02 and you could get away with a fairly small tank of O2. The tanks on the space station aren't that big. The pilots have to breathe their own separate air anyways, by law
According to NASA, each pump (there were 3) would drain a swimming pool in 28 seconds. https://www.nasa.gov/centers/marshal...r/ssme_11.html The High Pressure Pump (HPLT) was fed by a Low Pressure Pump (LPLT) The LPLT pressurized the fuel to 275 psi and then HPLT increased that to 6515 psi. Full story here: https://spaceflight.nasa.gov/shuttle...p/engines.html |
