The Aircar thread, a true unicorn or just very inefficient short range transport.
(my first well thought out air car thread dissappeared and never posted :( ah well, this one gets the point I guess but it simply doesn't sound as wimsical or funny)
The aircar BS has always amused me and the prototypes were always reviewed and hyped like any true unicorn but unlike most unicorns there is a kernal of truth, you could drive this unicorn 20 miles at 25mph or in the case of the air bike 18mph for 20miles. (real homebuilt vehicles) In either event to bust this unicorn we need the energy capacity of compressed air in a given volume versus pressure and reasons why the air car was only 5% efficient on a good day. That said the possibility exists for the air car to be usable for some people if we could overcome its dismal efficiency (similar to a model T with flat tires and a stuck carb) The reasons the air car is only 5% efficient is the pump is only 10-20% efficient on a good day and the motor very similar to the above, add to that the electric motor running the pump is typically only 80%; very sad story but could we do better with scale? I think on the compression side YES, heres why the existing pumps are so inefficient. 1. High pressure means very high tolerances and very high friction 2. High pressure means any small gap between the one way valve and the piston results in a heavy loss of compressed air (which is energy) 3. High pressure air seals always leak a bit and have losses while compressing. How could we over come this? If it were me I would think using a very tall depth of a liquid to compress the air with a low fluid resistance conveyor to bring the air to the bottom with minimal fluid friction could easily increase this efficiency (with scale) to well over 80%, with a good motor design perhaps 90%, all the air that would be compressed would be deposited into the vessel at the bottom, expansion losses would be minimal, frictional losses could be made minimal with the proper shape, size and speed of the vertical conveyor (ideally you wouldn't want the conveyor to really displace any water while it moved, proper surface shaping could reduce the fluid resistance). Anyone see any other ways we could make the air car efficient enough (albeat still very limited) to be usuable and reasonable on short distance vehicles? If a large scale system of efficiently compressing air were developed that could move the air car up to 10-20% efficiency (if some minor improvements could be made to the motor) with some limited regenability. Oddly that is the typical trip efficiency of most late model over the road cars. Anyone think using a fluid to compress air would be very inefficient? I don't see why it would be; bypasses almost ever negative that a normal compressor experiences (and the negatives on a normal compressor grow as pressures grow, whereas with a fluid it would not) Feel free to add the other strangeness discussed previously into this topic and any new strangeness you want, make my unicorn fly :) Cheers Ryan |
How about an air hybrid? You'd use a small diesel engine fitted with a Jake brake. Instead of venting the compressed air, you'd store it, and use it later for acceleration.
1. Initially regen braking power would be very small and grow as the pressure increased. 2. Once the pressure started increasing you could actually get to a high enough pressure that no more would be stored or possibly cause damage. (I lean toward no more energy would be stored but you would still have brakes) The limit to the air pressure would be whatever the motors compression ratio happens to be. This could maybe be used as a cheap low wear instant start stop solution for big motors or a method of reducing the pumping losses from the turbo during the initial takeoff. (it would require variable or controllable timing on the valves though) Actually, the more I think about it adding start stop to semis would be a great idea and being able to boost enough right after startup that they would never want to smoke wouldn't be a bad thing either. Not to mention cheap, any existing semi with a jake could be retrofitted in this way. Why add a pump when you already have an excellent 8 piston pump? Keep the unicorns coming. :) |
How much do high pressure air tanks weigh, I wonder? And, if they fail, they will explode -- they don't fail gracefully.
The pressure from a semi motor certainly wouldn't get into the massively dangerous PSI area maybe 270psi at most which is less than spectacular if it went. Could easily be designed with shell and relief to keep it safe, not to mention an onboard tank like that could be used to suppliment air brakes, AC, onboard air tools :) LoL Oh and did I mention most semis already have 120psi air tanks onboard anyway? Afterall how do they release the parking brake? |
No, tanks don't explode. Within their rated standard they are very safe. At worst if they do fail it is "gracefully" from rust and end up with a small leak - often in the form of pinhole corrosion, due to condensed moisture present from the compressed air in the tank. |
Thymeclock -
CarloSW2 |
The question does not seem to be if they work but how well, I don't think they work well because you are using electricity to compress the air and storing that energy until it's used to power the car, there is a power company that is doing something like this to store off peek electricity but they are freezing it to a liquid state then running it in a modern steam engine, more or less what an air car does with the compressed air, thing is, to make this set up work they need a way to keep the air engine warm and that is why it's not done here but they do play around with it in places like India that stay warm and everyone wants air conditioning, gas engines produce heat as a waste, air engines produce cold.
Somebody started this a while back. Seems Tata bought the idea. Tata Motors air-powered City Cat car readies for production run - Newlaunches.com
IIRC the issue was getting the onboard tanks approved by the transportation safety departments. |
I thought this thread was about compressed air. So what has hydrogen got to do with it? |
Our 250psi rated (they normally only go to 120psi during use though) air cans for automotive use (aka they are mounted on vehicles with air brakes) at the plant are light as a feather. You don't need to armor them, just put a shroud around them so when they are hit and punctured then blow the air, it is directed somewhere. Not rocket science and air the last time I checked isn't the most flamable or explosive of materials even at 300psi which is all a jake brake could ever develope.
That Tata car is as dead as a doornail, you will never see it and we all know why. It was one unicorn that didn't fly very fast or far or even very well. Quote:
Afterall gasoline engines began at about 5% efficiency, perhaps air motors with some work could get beyond this overall efficiency point? I am curious if anyone has some insite into what factors make a air motor more efficient (or make it inefficient) just as I outlined the actual reasons why the compressor isn't very efficient. Quote:
Thymeclock -
Compressors are not very efficient. And to carry a tank big enough to power the car even as far as EV, would be pretty large and heavy. The Stanley Steamer that set the land speed record (that stood for a very long time!) crashed and it's tank shot about a mile down the beach.
I'm not usually a nanny type but compressed air tanks are very dangerous if poorly constructed and sometimes the do fail catastrophically:
Stay from those old compressor--- - WeldingWeb™ - Welding forum for pros and enthusiasts The guy who had the misfortune to be in the same room when this went off is lucky to be alive. http://weldingweb.com/attachment.php...1&d=1294099030 http://www.youtube.com/watch?v=kIs8c...layer_embedded |
Several comments: The tank was obviously severely rusted. Common sense would be to check the condition of any tank before using it. The anecdote related that the idiot tried to run it up to pressures of 150 psi or more, probably bypassing the pressure switch, which exceeded the recommended pressure range. Obviously the pressure relief valve wasn't working. Lastly, Sears compressors are notorious for poor quality, although the other factors are the cause for the disaster. This guy would be a candidate for the Darwin Awards. |
...instead of those welded steel tanks, try looking at the spun, wrapped, fiberglass or carbon-fiber tanks like those used in airplanes, missiles and space craft.
