The airdam that didn't work
Last august I made a trip to georgia. Before I left I fabbed up this airdam. It gave 5.5" of ground clearance. It was made from 26 gauge HVAC sheet metal. The first 3 hours of the trip netted excellent results(tailwind). Upon turning south mileage plummeted. I put 750miles on it with worse than usual mileage. I did some early morning 60-30mph coast down test. The results were very close but the without the airdam I got a very light improvement. This confirmed my suspicions that it was indeed hurting performance. The airdam certainly had its advantages, the A/C worked as good as stock at highway speeds. The added high pressure on the cars nose made for excellent cooling properties(Which was nice for a trip to Georgia in august). It also just looked cool. I couldn't have gotten more looks if I was driving a hot pink pantera. It was however impossible to live with. Even the most gently graded driveway would defeat it. Gravel is the enemy of any airdam. It wouldn't last 20 minutes on an icy winter day. The presence of mind required to prevent its destruction was mentally draining. I think for proper performance in my case the airdam and belly pan must be integrated together.
http://i75.photobucket.com/albums/i3...MG0014_002.jpg http://i75.photobucket.com/albums/i3...MG0015_003.jpg |
Did you have the full bellypan before or after the airdam?
I've had excellent results with my airdam, though without a bellypan. I have since taken about 4" off my airdam (essentially making it a grille block) and added front and rear undertrays. I haven't had a full tank of gas through it since, but I'm interested to see the results. |
lovemysan, you should enter your car in the EM Garage so that we can learn from your experience. I just entered mine.
That was nice looking. I had a similar experience with airdams. I started quite radical with a 7" airdam. It looked interesting but rubbed alote (luckily it was made from coroplast so it held up well) and coast down tests showed a slight decrease in performance. I ended up shaving it so it was 3.5 - 4 inches tall (just enough to block most of the undercarriage components from the air flow). It looks okay, doesn't rub anymore, and the coast down test were inconclusive (showed no decrease in performance over no airdam) so I just left it on. I'm not using any kind of belly pan in the front of my car though. I may try a belly pan vs airdam once temps stay warm.
airdam (damn!)
Great photos,and love the look of your work! I think your project fell victim to the diminishing-return/negative-return,as the depth of the airdam added a significant increase to the cars frontal area,increasing drag by a corresponding factor.Should you have had Hucho's book,you would have found that if the airdam projects below the elevation of the lowest suspension member,drag will begin to grow as a percentage of the percentage increase in frontal area.Bummer! The book is invaluable to any one considering aero modifications and can soon pay for itself in time and material saved.
The air dam was 1" lower than the center section of the pan. The pan actually actually declines from the bumper to suspension 3-4". Also the airdam was not level with the ground it was 5.5" in the center and roughly3.5" on the outside. I'd like to get that book but don't have $40 to spend on it. I need new motor mounts.
What's behind the lower lip of that spoiler? Does it just hang down, or is there a tangential horizontal surface that is part of the undertray? Could make a big difference.
"Even the most gently graded driveway would defeat it."
I used to drive a tow truck and we had the same problem but for a different reason. If you drive up a steep grade in a tow truck while towing a car, the back of the tow truck drops and there is a risk that the car on the back will hit the road and fall off. (don't ask me how I know this) The solution is to approach any grade on an angle. Now for a speed bump this would be difficult, but where you are going into a parking lot that has a steep grade, try to go in at an angle, so only one wheel hits first. I hope that makes sense? Peter |
Heynow999 offers a good suggestion. I always see lowered cars take speed bumps and driveways at an angle. Speed bumps are handled with a zigzag pattern...moving to the leftmost area of the lane, cutting sharply to the right across the bump, and straightening out in the rightmost area of the lane.
I'd lose the antenna. I'd bet you'd decrease air drag a healthy fraction of a percent. :) - LostCause |
with your airdam, you have added more frontal area, and because your car (with many aero mods) it is very efficient, your have gotten worse the things. If I just remember, your car is equipped with full bellypan. You can try to reduce central height of airdam, this, reduce the FA, and permit to pass the air under your car. Look, the example opel calibra. Calibra equiped with engine undercover, use an airdam tested in windtunnel. After many tests, Opel are deliveryd an airdam shaped with raised central area, and high at the side. look the image below: http://img107.imageshack.us/img107/5400/calibramw0.jpg It permit to deviate the air from wheels and the suspension arm. I do not have any report, but in my car, I am insirated me to Opel for my front deviator if you try it, tell us the change. |
http://images.trucktrend.com/feature...+side_view.jpg Of course it's hard to tell from a photo, but I have also seen this on GM's full size panel vans. Maybe it's also a function of the relative "cleanliness" of the underside, apart from the height of the lowest parts. |
The new silverado is equipped with a very stealthy airdam also. It looks to drop just below the suspension though.
We have to be careful when we look at other vehicles. Remember, there are folks involved besides the aero engineers--those darn stylists and marketing departments have their say, too, and these days, what a lot of them seem to be saying is "Make it look more macho". One way of doing that is putting big airdams on the front (e..g., the SUV shown above). The problem is, you can't tell *by looking* what thinking led to the air dam being the way it is: was it the stylist who said "add two more inches to it" or the engineer who discovered it lowered the Cd by 20 counts? What we have to do is understand the aerodynamics and work from there (imho).
Ditto for what you see on NASCAR bodies: they have different constraints and different goals (airspeed = 200mph, super smooth tracks (no speed bumps to negotiate), and a need for negative lift). It turns out that front air dams have to do a lot of different things, depending on what's going on with the rest of the car. For example, I'm learning that wheel well size and shape have a lot to do with the aerodynamics of the front wheels--and that how the air dam affects air flow to that area has a lot to do with overall Cd. Second, you might notice that most air dams have a "chin" whereas the air dams lotsa people fabricate don't. I haven't researched that aspect yet, but just from my general knowledge of airflow, I'd have to say that I expect the chin has a major effect on helping the air flow to the sides rather than to the underside of the car (which seems to be the goal). Also, there is a concept of "mixing distance". The air flowing over the front of the car forms a boundary layer (both above and below the car as well as on the sides) which grows in thickness as it moves from the front of the car toward the rear. At some point (assuming a typical ground clearance), the boundary layer below the car becomes thick enough to touch the ground. The distance of this point from the front of the car is known as the "mixing distance". According to Road Vehicle Aerodynamics (see my Intro), increasing the mixing distance and decreasing boundary layer thickness by careful attention to the front of the car can reduce the total Cd by up to 10% (please note the "up to"). The author then goes on to describe the effects of underbody curvature (front to back and side to side) and shows that curvature helps lower Cd and discusses the interaction of this curvature with what's happening at the front of the car. The takehome message, it seems to me, is that a person can't just slap on a front air dam of an arbitrary size and shape and expect it to work (let alone be optimal). There's got to be some trial and error involved and the results *do* depend on what else is going on with the car. Wish it weren't so, but I'm afraid it is. --Steve |
Thanks, Steve, that's all good input and well reasoned.
I ask about the Calibra air dam because that car shape is quite similar to my Porsche 944 Turbo, which itself got significant wind tunnel attention in design stage. It has an undertray and chin fairing, although its nose shape has some unnecessary roughness in texture and contour. That said, the nose of the Porsche could stand some improvement, and various spoilers and splitters have been designed for it, with anecdotal reports as to respective efficiency. Many on this website have made significant aerodynamic improvements to their vehicles by home-made experimentation and some pretty good intuition. From this, we can surmise that the factory original is not necessarily the final word on design. Your post mentions some of your research and notes "mixing distance." Would you please tell us more about this, cite references we can Google, etc.? Seems to me, "mixing distance" may be the reason for some of the geometry on the BMW air duct posted hereabouts a few days ago--that at given speed, the turbulent air behind the air dam moves such as to help extract radiator cooling air. Please help us with more info on mixing distance, etc.. |
Otto:
What I said about mixing distance came from Road Vehicle Aerodynamics, mentioned in my intro. To my knowledge it is not available for viewing on the net--you'd have to find it in a library, probably a local college library. It has quite an extensive section on how airlfow through the engine compartment is designed--apparently, until recently, this has been where the *majority* of wind tunnel time has been spent! The designers work really really hard to make sure the darned ICE is gonna stay cool (and warm in cold temps) and airflow through the grill, the engine compartment, and under the car is obviously critical (as well as very complex). In general, the air under a car is at a lower pressure (because it's moving at a higher speed) than the air at the front--air moves from high pressure to low, so, yes, the air flow under the car has a lot to do with getting the air through the engine compartment. The problem with the boundary layer (and I'm just learning this stuff) is this: it is the layer of air that is trying to "stick" to the car, and is trying to move with the car while the air farther from the car is happy to sail on by. The boundary layer forms because air is viscous. At Reynolds numbers for road vehicles, the boundary layer becomes turbulent very quickly; however, the boundary layer may or may not separate. Now from an energy point of view the vehicle will lose less energy to a laminar (non-turbulent) boundary layer than it will a turbulent one, but the real killer in terms of energy loss is when the boundary layer (turbulent or laminar) separates. It turns out that a turbulent boundary layer separates less easily than a laminar one, so sometimes turbulence (at the micro scale) is good. Vortices, which are "turbulence" at a macro scale are something else. Now, you probably knew all that, but I mention it for the following: One problem (please notice I said *one*) with the boundary layer below the car is that it eventually thickens and meets the ground. The boundary layer (which is probably already turbulent and hopefully is still attached) is trying to move with the car but when it meets the ground, additional turbulence is created because the ground tries to retard the boundary layer. That additional turbulence (which may be "macro" turbulence--I'm not clear on this yet) represents a (small) loss of energy so the Cd has, in effect, just risen. If you can keep the boundary layer as thin as possible for as long as possible, you keep it from meeting the ground (i.e., you've increased the mixing distance) and you thereby lessen the gound-induced turbulence which means you've lessened the energy lost to turbulence. There are other things going on as well, so this isn't the whole story--but it may help you understand the mixing distance and its effect on drag. --Steve |
Steve say, correctly, is it impossible to think that when are installed in other car is absolutely good for we cars.
we can to observe other poduction cars, look some aerodynamics elements and analysing they with in mind that in some cases, the marketing people change the shape for aesthetic motivation. About the calibra airdam, my post it is only an example, and if we go to realize it for we cars, we must to inteprete little information that we have. In particular Otto, the measure of gap in the middle of the spoiler, it is conseguence of some aerodynamic interference (actions). Calibra, has full underbody pan, so permit to a good passage for air below car with minimal drag. In this case, I think than, it is preferible to reduce the fronta area with gapped spolier. Again, it is many important to deviate the air flow around the suspention ARM and any other element disturb of flow. |
lovemysan, or anyone with data, do you still have any of your coastdown info? I'm looking for road load #s for saturns like your's because I'm thinking about building an EV saturn. All I would need would be the average time it took to coast from 55mph to 50 mph (use the data from before the airdam if you have it). thanks
