Old 04-02-2012, 05:22 PM   #1 (permalink)
rainagain's Avatar
Peugeot 206 1.9D - '98 Peugeot 206 L
90 day: 44.91 mpg (US)
Worth blocking in back on hubcaps
I've given up finding pizza trays big enough to cover my wheels. Would it be worth blocking in the rear of my hubcaps? I've got some thin plastic disposable catering sandwich trays, I was thinking of cutting plastic triangles out of them and attaching them to the back of the hub caps.
I know the hub cap won't be smooth but will it help?
Old 04-02-2012, 05:59 PM   #2 (permalink)
the turd - '88 honda civic 4dr DX
90 day: 73.51 mpg (US)
yes it would, but you can buy a set of raceing caps witch is better from jc whitney
Old 04-02-2012, 05:59 PM   #3 (permalink)
Gen II Prianista
Rokeby's Avatar
Your mods will probably help, but not a whole lot,
which is to say it may not be measurable.
In total the wheel well and tire contribution to Cd for all four
wheels and wells is ~0.09. You might decrease that by 0.005
if you're lucky, which would mean gas savings out in the 3rd
decimal place of MPGs.
Then again, if it ain't hurtin' the numbers, why not give it
a go.
Old 04-02-2012, 06:24 PM   #4 (permalink)
That's what Metro did to his car, and he probably has a write-up on it.
Easiest and probably cheapest way would be to find some nice flat ones that fit at a junkyard.
Old 04-02-2012, 11:15 PM   #5 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I say, go for it. I would think keeping air on the outside of the wheel would be beneficial, whether the surface is perfectly smooth or not.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 04-03-2012, 03:38 AM   #6 (permalink)
rainagain's Avatar
thanks for the replies, I'll give it a go
Old 04-04-2012, 03:10 PM   #7 (permalink)
rainagain's Avatar
Ok here's the results:
Front of cap with gaps for valve and so I can tie-wrap it to the wheel
Back of the hub cap showing the plastic triangles glued on
Plastic triangles cut from catering sandwich serving tray (yes I get funny looks after meetings when I take the trays away!)
The Following User Says Thank You to rainagain For This Useful Post:
Rokeby (04-04-2012)
Old 04-04-2012, 03:11 PM   #8 (permalink)
rainagain's Avatar
I'll update if I get any improvement in mpg
