airspeed indicator
I don't get into the Instrumentation sub-forum much, living in a pre-OBDII world. but I noticed this:
https://4.bp.blogspot.com/-D-gG4XuC1.../we4rfgqwg.JPG Just A Car Guy: smart way to see if the mass air flow sensor works Rather than adapting a light-plane pitot tube, couldn't the output from a mass airflow sensor be read via an Arduino input and compared to road speed? The front face of a rear view mirror might be a good monitoring location, with an annular outlet. You could have one on each mirror and DIFF them for crosswinds! |
That could be a good tool for adding another variable into your fuel mileage calculations. It would give you true aerodynamic speed. for comparisons when you are evaluating changes to the body or running gear. 60 mph (through air) vs 60 mph (through air) regardless of ground speed.
(FYI: Within five minutes of posting you can Edit your post without accruing an edit notation. Just use the button in the lower right.) But hey, three replies. :)
An aircraft pitot tube is about a foot long to pierce through the laminar flow and best practice is to place it at a stagnation point. On a car that would be the nose. I don't know the velocities involved in the intake system. A tube smaller than the throat might make measurement difficult, else a bellmouth could gather more air. |
BTW, thanks for the edit tip. |
I just want to see a pitot tube installed on a vehicle, that and a wind vane to get wind direction too.
Of course, a malfunction of the pitot tube would likely cause the driver to stall the vehicle with tragic results. |
Ground vehicle "pilots" have a speedometer and other visual clues to determine their speed. The pitot tube is just for research. |
One can mouse over the links and see that it is no laughing matter.
http://3.bp.blogspot.com/-sPhqU1K6nv...ornament_4.jpg Just A Car Guy: Wow. Found in a box in the barn... the UFO hood ornament designed by Alex Tremulis Sparrow strainers. Dump the plastic housing and wind your own coil. :thumbup: |
There used to be charts available for airflow vs throttle position. However if you have obd2 you can read it semi directly, if you have a spare light plane airspeed indicator you could just drill a hole, shove a tube into the duct and read direct
Sounds like a great idea to me. I work with MAF sensors at work for their intended purpose, measuring airflow. Some quick numbers from an engine I'm working on now:
Idle airflow - 6 g/s Peak airflow - 660 g/s Air is about .0806 pounds per cubic foot. Just math to get to speed... With a 4" tube this equates to about 1 MPH at idle, and about 140 at peak flow. Seems like an appropriate measurement range. The ones I work with output a frequency, but there are others that output a voltage. Voltage being a bit simpler to measure easily. Just need some wind tunnel time to calibrate it. |
I had been looking into pitot tube + Arduino setups for an adaptive aero design.
Here is one product with a very reasonable price https://hobbyking.com/en_us/hk-pilot...itot-tube.html -Liberty |
There you go. Anything you can think of is available, you just have to know where to look.
Handheld wind-speed anemometer?
I had a friend offer me a hand-held anemometer at a swap meet, but I suggested he try to sell it first. So he gave it away to the next person. :(
I guess I don't mind because holding it out the vent window next to the rear view mirror is sub-optimal. |
