Old 09-13-2008, 10:48 AM   #1 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Which Arduino Clone?
I am using an Arduino Diecimila to put together a servo actuated throttle for a hybrid generator. I would prefer to use a lower cost clone for actual use to avoid damage to the Arduino that I am using now, which is set up for learning how to use it. The clone would be dedicated to this use only and would hopefully have a long service life.
This would be a high vibration application. I would like to solder connections. Once the clone is programmed, I probably would not need to make changes although tweaking is probably to be expected.
Which clone would be a good choice for this application?
If I were to program the chip in my Diecimila, and transfer the chip to a clone, will that work? Then I would not need the usb port on the clone, just a power port.
Nissan Versa Aeromods
Old 09-14-2008, 11:41 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I like my iduino,
Old 09-14-2008, 07:27 PM   #3 (permalink)
Red Beast - '82 Honda V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 Honda CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Dodge Neon SXT
90 day: 28.71 mpg (US)
Most of the 'duino branches will work. The only difficulties would be:
Voltage (Some are 5v some are 3.3v)
Code space
Interface to computer (some are serial, some are USB)
I have seen some as cheap as $5.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
OBD MPGuino gauge jmonroe OpenGauge / MPGuino FE computer 855 03-16-2018 08:47 PM
opengauge development: gunio technical considerations dcb OpenGauge / MPGuino FE computer 88 06-26-2008 10:14 PM
Arduino Nano SVOboy OpenGauge / MPGuino FE computer 0 05-19-2008 04:33 PM
