Old 07-13-2013, 03:20 PM   #1 (permalink)
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
lean burn while shifting!
Here is how to maintain lean burn while shifting in a Honda Insight, this may work on other lean burn engine but no testing has been done. So here is what I know, you must have a calpod/card/clutch switch. if you have the clutch switch "on" as in the car thinks the clutch is pushed in, while keeping your foot on the gas pedal even just slightly you can change gears up or down and still retain lean burn. I use it to climb hills by downshifting to 3rd or 4th or speeding up by shifting to 5th.
Here is the break down
you need:
1st. clutch/calpod switch engaged.
2nd. you need to already be in lean burn.
3. keep your foot on the gas.
4. shift quickly as to not over-rev.
5. Bam your still in lean burn changing gears!
Here is a quick youtube video showing me maintaining lean burn while shifting from 3-4-5 and 5-4-3.
The Following 3 Users Say Thank You to Insight for life For This Useful Post:
mikeyjd (07-13-2013), WD40 (08-16-2013), YukonCornelius (07-23-2013)
Old 07-13-2013, 08:55 PM   #2 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
you can maintain lean burn climbing hills by using this?
Old 07-13-2013, 09:03 PM   #3 (permalink)
Gen-1 Insights
yes.
Old 08-15-2013, 11:55 PM   #4 (permalink)
hmmm....I'll have to figure something out with the 3 stage vtec.
Old 08-16-2013, 12:10 PM   #5 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
wow thanks for this tip .. it works great in my VX
2000 Insight MT 106K Citrus A/C
