Almera 2.2 sport+ (2000) wont start..please help!
Hello, I have a Nissan almera 2.2 sport+ (2000), I started to have problems with starting the car first time until eventually it wouldnt start at all, I was told it was the starter motor so I purchesed another, I have fitted the new starter motor and it still wont start, all I get when I turn the ignition on is a clicking noise, Just to make sure there wasnt a fault with this starter motor I had it bench tested and it fires the cog out no problem but as soon as it is fitted back onto the car and ignision is turned all you hear is a sound like an electric motor turning coming form the starter motor but its not fireing out to engage with the engine.
Will it start if jumped? It sounds to me like a weak battery if you already replaced the starter. which means it could also be the alternator not charging the system back up
Thanks for your reply....It wont start form jump leads from another battery and ive just tried my neightbours battery in my car and that wont work either..its got my head banging ha.
well all i can think of is checking the hot and ground wires to the starter. If the problem got progressively worse and then u replaced the starter. then i could see either a bad connection or a locking motor
Thanks again for your reply....what do you mean by a locking motor?
some one has just told me that it could be the cam/crank sensor..could they be right??...if so where is the cam/crank sensor located??..again thank you.
Both could definitly do it and if there starting to fail would not throw codes until its completely bad.( How'd i forget those i had replaced both on a car, i guess it was because it didnt fix my issue, but my ecu was dieing come to find out). the crank sensor is by the starter, and i couldnt find the 2.2 cam sensor but depending how close the 2.5 is in comparison...http://www.youtube.com/watch?v=ndHU6TnsJ_E
The sensors will keep it from starting, but it wont affect the starter motor in any way.
Is it by any chance stuck in a gear? Is it possible to push the car? If not it' stuck in a gear. Some time this can happen with an old worn gearbox. Try to push or tow car and get i aout of the stuck gear?
Sounds like you can push start it? If that is what a "bump start" means. You need to test the connections from the ignition switch to the starter motor. You set a volt meter to 12 volts then connect the meter at the beginning and end of the signal path. If you find a voltage reading above .25 volt you have a bad connection in that circuit. Start at the battery positive cable and the starter power connection. Then work your way through the circuit if you get a voltage reading of over .25 volt which indicates a bad connection in that circuit.
My first guess would be a bad ground that is not letting enough power to the starter for it to work. This would allow you to push start the car but it would not start with the starter motor. Another way to test it would be with a push button starter bypass switch, like mechanics use to move the engine around to check the valves. It goes from the postive battery terminal to the starter solenoid and bypasses the key operated ignition circuit. If it works this way you have a bad connection in the keyed ignition circuit. If not then it is more likely the ground circuit from the starter back to the battery, regards Mech |
sounds to me like your ignition switch is dead in the start position; one of two things can be done;
1. change out said ignition switch 2. wire in a start button |
I know this thread is old now, but just wanted to say I think baldlobo is right, I had a 2.2DI Sport+ and it was the ignition switch. Bought a new one from Nissan and replaced it myself. Fiddly job but do-able if you're fairly competent. The ignition switch is directly behind where you insert your key.
