EcoModder.com
-   -   Almighty's GP Mod Thread (https://ecomodder.com/forum/showthread.php/almightys-gp-mod-thread-5891.html)
almightybmw 11-06-2008 06:48 PM
I finally did something. I got sick of the cold mornings, and the 10 minutes till the cabin is partially warm. Found some old cardboard boxes, cut them up, and covered most of the grill/bumper openings. It's not pretty, I didn't paint them, I didn't even try to make the cuts straight or even. I just wanted to see how it would affect the warm up times.
http://ecomodder.com/forum/emgarage-...2d3d9642e8.JPG
You can easily see the white cardboard behind the upper grills, and the brown behind the lower.
http://ecomodder.com/forum/emgarage-...5e953fcfd5.JPG
See the simple screws? the lopsided mount? There are vents on the horizontal plane. This car has too much cooling.
It's functional, and ugly. If it works, I'll clean it up with plastic molded to the bumper, which I'll have to take off. Not an easy car to work on. I left one open, because it's a pain to get the cardboard to stay.
Just filled the tank, I'll drive the same (lots of throttle when I'm bored) and in 330 miles/3 weeks we'll see if it made a sizeable difference in warmup and mileage.
RH77 11-06-2008 11:40 PM
Good work -- I did that my first year of blocks, then graduated to discarded baking pans. It sure will make a difference, that's for sure.
Let us know how it works!
-Rick
