Almost 50 mpg
Well so oh so very close. 49.97. Not bad considering all I did was drive it 55-70 on freeway. New 02 and 40 psi. No coasting no aero mods no warm air intake. Quite pleased. Had I not run some errands in town would have been 50. Vx rocks. What would a warm air intake or belly pan net me?
uotstanding!!!!!
Warm air intake may not help as much, your vehicle should be keeping plenty warm- as compared to the belly pan. I would advise grille blocking first, it would easily get you to 50 mpg under like circumstance (they often net 5+%) and a lot of air in the engine bay will try to come out the bottom of the car, and may have a negative affect on the belly pan.
I should also mention I am missing the vx si front lip. Lower chin on bumper. Hmm. So front grill blocks here I come.
I've found keeping my freeway speeds under 60 really has a big effect on my mpgs. Just remember slow traffic stay right.
what he said
49.97? Should have pushed it around the parking lot a few times to hit 50! lol
Very nice work. I am planning a belly pan as well within the next month or so. Currious on what effectit might have on my grill block though. If it is negative I might just do the rear belly pan. Either way I am going to tackle it in two sections as it seems much earier and has similar gains to the full version. |
I found the belly pan helpful, along w/ the grill block.
look at the third link in my signature, I ended up having a front and rear pan and skipping the middle! |
I have a volt meter hooked up so I can monitor lean burn. I am going from 55-70 depending I've got some rolling hills so gotta try to get speed to keep seep up long gradual grades. We sold our house so belly pan is on hold. I do have rolls of aluminum coil stock. 24in wide by 50foot it's what siders use to wrap window and door casings. So I thought possibly that with some stiffing ribs or even just that with a few aluminum angel run down the car. Hummm. Turbo If you want I got a front sway bar for a 96-00 civic. I only have the bar and brackets I think. Come and get it. Or I could ship if you want. Let me know. I was told it would fit a 92 but no. You need the back half of he front lower arms with a hole in them. They are from any 92-00 that has a bar. Well see about this tank it's been a little warmer and I've run less short trips so we will see. Right now it's getting hot and I'm turning into a baby I need a/c fixed.
