EcoModder.com
-   Fossil Fuel Free (https://ecomodder.com/forum/fossil-fuel-free.html)
-   -   Alt fuels stations opening (https://ecomodder.com/forum/showthread.php/alt-fuels-stations-opening-24156.html)
Frank Lee 11-30-2012 04:38 AM
The Gas Station of the Future Just Opened - Businessweek
fyi
serialk11r 11-30-2012 04:47 AM
There's very few Propel stations around, I put a gallon of E85 in my tank 2 tanks ago to see if it did anything differently (20% ethanol instead of 10).
The problem is that their prices SUCK. 3.85 for a gallon of E85, when 87 gas was 4.59. You have got to be joking me.
user removed 11-30-2012 08:33 AM
One issue with running alcohol in a conventional spark ignited gasoline engine is compression. I think Indy cars run compression ratios around 14-16 to 1. The much higher octane rating of pure alcohol and even E85 allows much higher compression, which means you need to have the engine designed specifically for alcohol. It would be interesting to see if the Mazda SKY-Activ gasoline engine would utilise the higher octane of alcohol.
I wonder what an alcohol-diesel blend would do with the much higher compression of diesels? Just a guess, but you may also run into NOX issues with the higher compression.
I know Brazil has been using alcohol for decades. I wonder if there are engines used there that are designed for alcohol specific use?
regards
Mech
gone-ot 11-30-2012 12:50 PM
It's not a hydrocarbon-fuel station, but one of our bookstores recently intstalled a "free" electric-vehicle charging station infront of each of their 3 stores here in Tucson. Wasn't able to see if it's for GM, Toyota, or tim-buk-tew tricycles.
