Alternator efficiency
Stumbled across this paper.
http://www.delcoremy.com/documents/h...ite-paper.aspx Some intereting info, they indicate alternator efficiency is highest at 30-40% load and 2,000 - 2,500 rpm. So maybe gearing down to 1:1 to engine and only activating alternator above say 1,800 rpm may improve overall efficiency. |
That is an interesting paper. It makes sense, just good to see it in one cohesive argument. Is there a way to determine the efficiency of your current alternator? I assume you can use a multimeter for the output, but how do you determine the amount of energy going into it?
I wonder if one wanted to have a more efficient alternator at a higher RPM, what would need to be done to make that work. More/heavier coils, lighter stator, domething else? |
That's one of the papers I looked at when I re-ratioed my alternator and water pump: http://ecomodder.com/forum/showthrea...ork-20558.html
I too much driving at 800 engine RPM, where the alternator is barely keeping up with the base electrical load. That's 25 MPH in fifth gear.
I'd have to put in a deep cycle battery if I re-ratioed the alternator. I'd be better off to do a full alternator delete with a switch for those long trips. |
Is there a way to do a pulley clutch? Like an A/C or hydraulic fan, but instead of the clutch forcing it off of the drive belt, it would just change over to a different size pully. Then at idle speeds, you can have 2:1 or 3:1and at higher speeds it will "clutch" to 1:1.
I guess that wouldn't really possible, since it would change the size of the belt needed to function properly. |
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1381772162 On all the cars and trucks I've seen the alternator sheave is much smaller than the crankshaft sheave, maybe 1/4 as big for old Chryslers. -mort |
Can anybody answer my original questions: how to determine your alternator's efficiency and how to make an alternator more efficient at a higher speed? |
that 1200 might have been the first test point. assuming a 2:1 pulley ratio(which is pretty slow compared to a lot of the units i've had), that's a 600RPM idle. assuming 3:1(which is pretty realistic for my applications), that's 1800 alternator RPM, which is 40 amps or so.
Not really. I don't drive it enough. It HAD to help but how much I can't say.
