Amt or auto clutch
Hello friends. Hope all are safe.
I drive a Hyundai Grand i10 with a 1200 cc engine. I primarily have to drive in stop n go traffic, this has caused knee pain due to excessive clutch usage. I was wondering if I could build an amt or even an automated clutch. The clutch could be automated or manually controlled using a potentiometer and electric motor combo for precise position control. Has anyone here tried anything like that? |
I suspect that by the time you did this, you could've just swapped in an auto transmission. It looks like that, roughly, is a 6 kmpl drop in efficiency, though (about 3 mpg).
Tough call. Anything is possible, it's just a matter of paying for it and designing it. You'd need a heck of a motor to push the clutch in all the way, I'd imagine. That could be negated a bit with gearing or a lever arm but even then. It's probably a tight fight under the dash of that thing. If there's no factory AMT, I wouldn't pursue it. Building your own would be about as complicated as installing an auto, maybe even moreso. I've never heard of either being done, nor could I find an example. Everything I looked at was swapping manual > auto or vice versa. |
Such adaptations cater mostly to drivers with some physical disability.
Since you're in India, try this: Ferro Equip |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
