Another Air Powered Vehicle
http://blog.makezine.com/archive/200...C-0D6B48984890
Original story link is dead :( But that's Make's coverage.... IIRC Range: 7 miles Top Speed: 18 mph The maker said it's really not practical for long commutes - but perfect for a fleet of delivery scooters. forgot the photo :D http://blog.makezine.com/AirPropelVe...tMechanics.jpg I wonder if he fills the tanks to their rated psi.... High pressure air isn't something everyone has easy access too... |
Probably a fun project though. |
with the stack of regulators he has I would guess that he has high pressure tanks, 3,000-5,000psi I would guess, not sure where you get a compressor that will handle that kind of pressure, but if those were in the 150psi range then I would guess he might get a mile or less at 10mph or less out of a fill up.
about ten years ago I read about a guy who had a bicycle that was air powered, had a custom over sized frame and it apparently increased speed by about 3mph, of course it had a low pressure system, with an on board compressor for use going down hills. |
Is that perhaps a LED headlight he put together there?
