another hho scam
Hi
while board as on sick following shoulder op i came across a download on google play. It was for a hho system seemed believable until it said rust proof engine internals wtf. |
translation:
• "While bored, as in sick, following shoulder operation, I came across a download on Google play." • "...rust proof engine internals..." --as in: to rust (verb)--because the HHO system (apparently) claimed to make the engine internals immune to rusting. |
lol at the concept of fuel rustproofing an engine. Mixing into the crankcase because oil just isn't cutting it! Wait it's supposed to do that? :p
There are many scams out there, this one is quite said. If anything it makes the exhaust rust more because of the increased water vapor in the exhaust. Also unless you filter out the harsh corrosive electrolyte via a bubbler that's going into the engine, exhaust, etc and will multiply the rust effect.
I heard if you put HHO in your coolant system it makes your exhaust come out in rainbow colors.
If you put HHO in your shampoo it makes your hair come back! If you put HHO in your soap... don't... :D |
