Old 12-02-2017, 03:30 PM   #1 (permalink)
Renault - '06 Renault Megane II
90 day: 38.41 mpg (US)
The question of the place of a rubber overlay to the bumper.
Hello, I would like to know which place is best to put on a rubber overlay? In the blue or red spot in the picture?
Last edited by airbiteses; 12-02-2017 at 03:35 PM.. Reason: The question of the place of a rubber overlay to the bumper.
The Following User Says Thank You to airbiteses For This Useful Post:
aerohead (12-02-2017)
Old 12-02-2017, 04:00 PM   #2 (permalink)
beastie - '89 toyota hilux dolphin motorhome
Puggie - '98 Peugeot 406 Lx
Me i would go blue and wrap around to front of wheel arches. Sure some else with greater knowledge than me will guide you.
Old 12-02-2017, 04:09 PM   #3 (permalink)
which place
In Wolf H. Hucho's book,he devoted an area of the text to airdams.He showed all the variants of airdam locations and sizes,and there was nothing intuitive about any of it.
There is a risk that Renault has already optimized the existing nose of your car.
Renault has constructed cars with Cd 0.13 already, and they know a great deal about streamlining.I'd be reluctant to try and second guess them.
BamZipPow (12-02-2017)
Old 12-02-2017, 04:23 PM   #4 (permalink)
The one on the picture is 0.35 Cx. The problem is that the rubber pad is not only 90 degrees, but only 120 degrees.
Old 12-02-2017, 04:43 PM   #5 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
120° as in the bottom is further forward than the top of the air dam, more like the chin splitter on a muscle car than an air dam?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 12-02-2017, 05:07 PM   #6 (permalink)
No more like the picture just a little lower angle.. I can not attach a photo because it does not allow me something here. Tomorrow I can take a picture of what the bottom of the bumper looks like.
This is how a rubber strip looks like:
This straight line from the top is glue.
Old 12-02-2017, 05:48 PM   #7 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Seehttp://ecomodder.com/forum/showthrea...rty-35894.html
This was my experience with testing . Will be the best answer. A pic from the front highlighting what the manufacturer did would help. As you said tomarrow.
Most moddern cars use a Spat. A small 1-2 tire with mudd flap looking thing 1-2" vertically angled slightly to the outside 1/3 tire. This softens the angle of impact, and redirects the air to go around the front tire with the smallest protruding wake(hence they stop short of the edge of the tire). This reduces the increases of frontal aera to the smallest number with the maximum effect. At some point the increases in frontal area offset the improved side flow. Theas spats that I have seen (I freek out car sailsmen and start asking them aerodynamic questions wile looking for the patterns of what the new technology is hidden by bodywork) typically start about 2" rear of the red and finish about1.5-2" forward of the finder openings.
Coefficient of drag down, Aera up at equal percentages will net a zero change. Its about finding a balance. And that can only be found by mesuring . To improve accuracy add a vacuum gage so you know if your driving teckneek is consistent or if the results are skued. If posable drive 30mi prior to startingthis test session to insure everything is constantly warmed up.
Former
87' Hyundai Excel
Old 12-03-2017, 03:49 AM   #8 (permalink)
What are your goals? Downforce (for stability) or lower drag for economy?
An airdam may require other modifications. Porsche found that on their 911, an airdam required a rear spoiler, and vice versa, for best effect. You may want a partial bellypan instead.
How much day-to-day trouble are you willing to put up with? Some people won't accept anything that alters the stock appearance. Problem?
Old 12-03-2017, 07:03 AM   #9 (permalink)
This what my front airdam looks like
Name:	Front air dam 2.jpg
Old 12-03-2017, 07:06 AM   #10 (permalink)
View from side
