EcoModder.com
-   -   Another Radical Idea (https://ecomodder.com/forum/showthread.php/another-radical-idea-36164.html)
Angel And The Wolf 02-15-2018 10:34 PM
1 Attachment(s)
Forget this design. I've superseded it with a trailer. (See permalink #13)
Frank Lee 02-15-2018 11:00 PM
Of course that can be done provided it's built stout enough. Not sure I'd want to drive around with that heavy a tail unless it provided another use like good strong cargo carrying capacity that would actually get used.
freebeard 02-16-2018 02:51 AM
These radical ideas all follow a theme.
Compare to a higher tail that gets you the departure angle you want, and has a flying wheel that only has contact before the boat tail proper ground-strikes. Since it doesn't have to carry the weight for three wheels, it could be lighter.
Angel And The Wolf 02-16-2018 06:09 AM
Edited. See Permalink #13
Hersbird 02-16-2018 04:06 PM
What would be really radical would be to make it strong enough and always in contact with the ground carrying the rear weight. Then remove the entire rear suspension, smooth the openings and have a trike.
Grant-53 02-16-2018 04:19 PM
There is a trade off between fuel saved by improved drag reduction and lost from the increased weight penalty. Decide how much cargo capacity and access you need in the rear. Consider a tub structure rather than a beam support.
Angel And The Wolf 02-16-2018 08:00 PM
See my new design for the linkage at Permalink #13
redpoint5 02-16-2018 08:28 PM
What is the advantage of the wheel? When it isn't touching the ground, it's placing extra stress on the frame, and when it is hitting the ground, it's due to lack of clearance, which places a great deal of stress on the frame.
Commercial airlines don't use tail wheels, but instead leave sufficient clearance to maneuver.
I'd say go with the KISS principle.
EDIT: Nevermind, I get the purpose. Design the most aero efficient angle on the tail and mitigate the issue of tail strikes.
What about placing the tail on a spring loaded hinge so that a friction surface on the bottom of it strikes the ground and moves the whole thing up, and then returns to position once clearance is no longer an issue? Better to move the smaller, lighter object than to make the whole vehicle conform to it, right?
oldtamiyaphile 02-16-2018 08:45 PM
Trailer hitches are designed for down loads of around 200lbs. This design would be a good way to bend chassis rails or rip the attachment points clean out of the chassis.
Angel And The Wolf 02-16-2018 09:10 PM
1 Attachment(s)
OK, I'm going back to the one wheel U-joint stabilized trailer. Forget the drawing below. See Permalink #13
Angel And The Wolf 02-16-2018 09:13 PM
OK, forget the first diagram. I've changed it into a trailer that has freedom of movement only up and down, and left or right. (See permalink #13)
Angel And The Wolf 02-16-2018 09:17 PM
I've abandoned the first idea. See my new diagram at permalink #13
Angel And The Wolf 02-17-2018 12:14 PM
1 Attachment(s)
Let's ignore, for the moment, the shell of the trailer. This is the mechanism that will allow the trailer to move both up or down to follow grade changes, and left or right, for turns, and at the same time, without allowing the single wheel to fall on it's side. I was having trouble envisioning how to keep the movement centered on the same vertical line, but I think I have it now:
freebeard 02-17-2018 03:04 PM
I'm skeptical. The roll resistance has a 0-length lever arm.
Why? You could have a one foot lever-arm between the horizontal and vertical hinge, with a 16" transition piece. And two hinges widely spaced hinges, both horizontally and verticall, enableing lighter construction.
That would mean a transition piece between the car body roper and the tail, but the gaposis would be on the top at the front and on the sides at the back
Copyright ©2000 - 2021, vBulletin Solutions Inc.
