EcoModder.com
-   -   another rim width question. (https://ecomodder.com/forum/showthread.php/another-rim-width-question-21072.html)
mikehallbackhoe 03-21-2012 01:13 AM
I researched rim width, but never found an answer. will running the same size tire on a wider rim lower the heighth of the tire. if that is the case, a wider rim should lower mpg. my crx has 4" wide rims, but one of them looks like it has been replaced. I haven't determined if it is 4", or 4.5". it is on the front. . I am thinking I should switch it to the rear until I can determine the width, or find a replacement rim. Am I worrying about nothing because of the small difference?
euromodder 03-21-2012 03:21 AM
Depends on the situation.
Ideally the sidewall is near vertical, and the tyre isn't stretched out or pinched in to fit the rim.
If I look at my own tires, 205/55R16, these may be fitted on 5.5 to 7.5 in wheels according to Tire Size Calculator - tire & wheel plus sizing so that's 5 rim widths.
Even though the fitment might be totally fine, a wide rim will angle the sidewalls out , while a narrow rim angles the sidewalls in, both giving a marginally lower sidewall height (when measured vertically).
Starting with a pinched-in situation, a wider rim might pull the sides more vertical.
CapriRacer 03-21-2012 06:46 AM
Not enough to worry about.
Vekke 03-21-2012 03:24 PM
What about the aerodynamic effect. Shouldnt you also try to get same 10 degree "kammback" shape on to the tire to lower their aerodynamic resistance?
That I will try to test this summer also on my Lupo. Try to stretch the rubebr to 10 degree angle.
I agree that effect to diameter does not have measurable effect, but what about the aero?.
I have my own eco tire designed for less aerodynamic drag wise plus some other tricks, but Nokian Tyres did not see that that kind of tire would fill their requirements for tires they have.
I can send the file to any tire maker who is willing to make the first tire to my lupo size spec ;).
larrybuck 03-21-2012 11:57 PM
It is obvious this is bothering you, so move that wheel to the rear.
You KNOW you will sleep better. Now, in your dreams, count the left, and right sweepers,
and sharper corners you take in your travels. Picture yourself coasting rapidly down those mountain roads when the pavement is wet.
Now you know which side of the back to put it on for a little extra insurance of control!
(you know I'm partly teasing here; right?)
mikehallbackhoe 03-22-2012 01:19 AM
my main concern was difference in diameter between the two drive wheels. but if they are close enough to not make a difference, I am not going to worry about it. thanks for the info
Ladogaboy 03-22-2012 02:34 AM
I wonder if a potential difference in weight/drag could affect the driveline? It's probably inconsequential too, though.
mikehallbackhoe 03-23-2012 09:35 PM
okay, I kept looking at that front tire, and how it looked so much wider than the other tire. I pulled it off ,and weighed it. 29lbs. pulled the corresponding rear tire and weighed it. 26lbs. I put the wider rim on the rear. It seems to steer easier, and it is probably my imagination, but it seems to have more power. my stock rims are 4.5", I located another 4.5" rim , and am replacing the 175 70 13 tires with 165 70 13 tires monday. the larger rim was only .5" wider, but it sure looked out of place compared to the other rims.
Ladogaboy 03-24-2012 02:35 AM
So strange... I'm guessing the person couldn't find a stock replacement?
euromodder 03-24-2012 11:53 AM
I can feel the weight increase through the powersteering when I put my heavier summer tires on.
It's no imagination.
euromodder 03-24-2012 12:10 PM
I'd think they can save far more fuel by concentrating on RR.
In order to keep the contact patch the same, the rim would need to be wider and the tyre would be stretched wider than necessary - that would give it more frontal area than needed - so that extra drag would need to be overcome before any benefit will show.
On 100mm of sidewall and 10°, you're looking at 18mm each side, that's a bit of stretch but I've seen worse on ricers.
Vekke 03-25-2012 02:42 PM
I dont think the frontal area would increase that much. Normally the tire is fitted like a donut so its much wider than actual contact patch. Then it just goes back to same width as the contact patch. More wider part would come on the higher proportion so its almost behind the front bumber or front tire spats.
https://www.facebook.com/photo.php?f...type=3&theater
Center of the tire is low rolling resistance compound and outer edges more grippy...
Vekke 03-25-2012 05:31 PM
Ford Hydrogen Fusion 999 Photo Gallery - AutoblogGreen
That tire is stretched and is there any other reason for that in speed record car than reduce drag?
mikehallbackhoe 03-26-2012 06:44 PM
finally got my new tires 165 70 13, and all 4 rims the same size. ride is more quiet, and it seems to have more power. my old tires max psi was 36, and these are 44 psi. took a while to convince the tire guy to air them up to 44, but he finally gave in. can"t wait to go through a tank and check the mpg.
