Any one know how to chemically weld motocross fairings
My dirtbike’s fairing broke (rear mudguard) and I would like to chemically weld it back to one.
I tried acetone and it had no effect, so I am assuming it is not ABS. It could be polypropylene or polyethylene, but I do not know what is a good solvent for those. If I succeed, could make a few bucks repairing fairings for others. I have some Methyl ethyl ketone on order will try that next but i am doubtful. (Bike is a 2007 yamaha YZ450F which may or may not have original plastics) |
-mort |
Thank you for the info. I have been looking at the chemical compatibility charts for some time now. But it just says incompatible without an explanation, does it melt or disintegrate...
Some solvents are not easy to get a hold of. 1,2,4 trichlorobenzen is a solvent. But i think it may need high temperatures. https://www.researchgate.net/post/Wh..._Polypropylene 3rd post has a downloadable pdf where they try to dissolve PE PP and PS for spin coating. "Polyethylene and polypropylene have high crystallinity degree structures, which means that to ensure dissolving of polymer pellets in solvent, the solution should be heated above the polymer melting temperature. These are 120-130 °C for polyethylene and 160-165 °C for isotactic polypropylene. To ensure fast polymer dissolving, the solvent must have a boiling point that is higher or comparable with the above mentioned temperatures and so decaline, anhydrous 99 % purity (Sigma Aldrich, mixture of cis and trans) was used (boiling point range of 189-191 °C). It should be pointed out that solutions of polyethylene and polypropylene in tetrahydrofuran and toluene are possible but require more than 6 hours to be obtained. When decaline was used as a solvent and the temperature was above 160 °C, complete polymer dissolving in both PE and PP cases were obtained in less than 3 hours. After the solution has been obtained, great care must be taken with its handling. The droppers used to transport the solution to the wafer need to be heated to 120 °C. The spin coater chuck should be heated up to 60-80 °C as well. The Si wafers should also have temperatures above 160 °C to ensure uniform surface wetting. If the temperature is below this value, PP and PE solutions adhere non- uniformly due to the high solution viscosity, as shown in Figures 5 and 6 respectively." The process seems a bit too involved for my taste. |
Most solvents and glues are adhesive. A few mollusks produce a glue with chemical action, and they are being studied.
DDG/?q=mollusk+chemical+bond+adhesive Quote:
Toxic and highly flammable Don't heat & breathe it All the stuff you named, can be glued with commercially available glues Better find out what it is first |
Can you plastic weld, meaning use heat and similar plastic to fuse it?
JB weld or other epoxy? |
Have to ask, why do you want to weld it instead of just replacing it?
Harbor Fright sells a plastic welding kit that is pretty cheap and might work. I've heard that it works halfway decent.
There are also friends bikes with broken fairings that could do with a bit of fixing. But most of all it would be a good learning experience. Add something to the skill set. |
You may be thinking of cement used for styrene in models. I use epoxy on fairings.
