Old 06-20-2008, 12:43 AM   #1 (permalink)
a/c belt clutch on alternator?
does anyone think that for a more reliable car, adapting an a/c compressor belt clutch onto an alternator. somehow have it controlled to only cut the alternator on if the engine is running and the voltage drops below a set threshold. does anyone think that engine drag could be reduced while still keeping the battery topped off?
Old 06-20-2008, 02:08 AM   #2 (permalink)
Red
Red's Avatar
I thought that was the purpose of the voltage regulator in essence? To various the output load on the alternator to whatever the given electrical system demands are?
Old 06-20-2008, 03:40 AM   #3 (permalink)
i just figured the clutch could further reduce the mechanical load the engine was subjected to while not giving up the cars ability to charge its battery. at any rate it was just an idea and seeing as how i dont have time/money to test out my ideas i figured run it by the "brain trust" of sorts being forums.
Old 06-20-2008, 11:14 AM   #4 (permalink)
ttoyoda's Avatar
When you finally DO turn on that ac clutch it will use electricity.. If you are going to charge the battery at home, and this is just a fail-safe for you then it might be ok.. Although you might get the same effect from switching the alternator off (the rotor field coil, NOT the big output wire)
Test: Alternator vs. no alternator = 10% MPG gain @ 70 km/h MetroMPG EcoModding Central 450 10-27-2023 09:40 AM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 07:52 AM
Alternatives to the alternator Stan General Efficiency Discussion 36 10-18-2008 02:15 PM
How get a shorter belt........ }{ead$hot Zod EcoModding Central 4 04-23-2008 11:13 PM
