EcoModder.com
-   The Lounge (https://ecomodder.com/forum/lounge.html)
-   -   Anyone else ever seen this... (https://ecomodder.com/forum/showthread.php/anyone-else-ever-seen-15278.html)
Kyleyadon 11-24-2010 06:03 PM
Years ago I came upon this website The Fuelless Engine Plans they sell plans for building different types of "free" energy devices. I actually got their plans for building your own hydrogen electrolysis fuel cell, and while the results were less than impressive, I blame that on the fact that I didn't exactly follow the plans and built one out of items I had laying around, namely a mason jar and some nails. I ask because one of their offerings, they call the fuelless engine, is a high efficiency electric motor that if indeed it is all it's cracked up to be should be of interest to anyone thinking about doing and ev conversion.
dcb 11-24-2010 06:35 PM
heres the vegas odds on that site
bullcrap: 99.99999999999999999%
truth: 0.00000000000000001%
tumnasgt 11-24-2010 06:57 PM
Laws of physics say no. The energy input must be equal to the output, and as there is friction etc to overcome, the engine wouldn't be able to maintain itself, let alone power anything else.
Perpetual motion machines are a fun idea, but are a complete load of crap. Anywhere that tries to sell plans for such a machine is a scam, and everything else they sell is almost certainly equally dodgy.
KITT222 11-24-2010 10:12 PM
Good tip: if you haven't heard of it anywhere else other than on their website, chances are that its a scam. If there is some miracle blue pill that will shoot your MPGs to the upper 300s you'll know about it pretty fast.
Kyleyadon 11-24-2010 11:30 PM
I actually expected as much, and since I've only seen this in the one place, I was curious as to whether or not anyone had seen something similar somewhere else. I know that electrolysis will work to produce hydrogen, however the issue is producing it at a high enough volume to provide the pressures needed in an engine. Also there's the issue of a power source that can operate the fuel cell that's small enough to be portable. However a highly efficient high hp electric motor would be an ideal item for ev conversions, and while one that's an over unity device may be an impossibility, one that uses less juice than current standards shouldn't be so far fetched.
camopaint0707 11-24-2010 11:42 PM
was it one of those water for gas things making hho?
autoteach 11-24-2010 11:56 PM
My car actually produces gasoline and O2 as a byproduct. It runs solely off atmospheric NOx, CO, CO2, HC's, and other byproducts of cars. I just need to draft close enough to them to dock with them, like this:
http://www.youtube.com/watch?v=s8-QtfHzG5s
Kyleyadon 11-25-2010 12:00 AM
Yes, camopaint0707. The theory behind water for gas is actually pretty sound, it's really just a matter of making an efficient and portable device for it. It's been known for a very long time that running electric current through water causes it to break down into hydrogen and oxygen with the two elements being attracted to a separate pole, but these devices require a lot of energy and tend to produce a lot of waste heat. The item that's on that site that I found most interesting, and was more curious about, was their "fuelless" engine, which is just an electric motor that they claim produces as much electricity as it uses.
Kyleyadon 11-25-2010 12:06 AM
Very interesting idea, autoteach, seems like a new twist on the old idea of gassafication. Though with the need of a specially equiped vehicle to dock with for refueling I wonder if you gain more than just a curiosity item of a truck. Though if you could attach a wide area scoop to it it may have some very useful applications in heavy traffic situations.
euromodder 11-25-2010 06:27 AM
A fancy capacitor ?
Piwoslaw 11-25-2010 08:41 AM
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1290692468
Kyleyadon 11-25-2010 02:37 PM
Perhaps euromoder. The thing that first intrigued me in the site was their claim that their work is based off the work of Nikola Tesla and Albert Einstein, I don't quite see where Einstein fits, but can see the influence of Tesla.
euromodder 11-25-2010 03:26 PM
Wild claim.
Conspiracy against the idea.
Mythic shape (pyramid).
Videos that show nothing useful.
"Based on" the works of scientists that most people can't comprehend anyway (Einstein) or who's ideas didn't always work (Tesla).
Does anyone really need any more convincing ?
Oh, their free heating system refers to the free engine ... a double whammer !
I'm not surprised by their claims, I'm surprised it's legal to run this sort of "business".
Kyleyadon 11-25-2010 03:44 PM
True, sad thing about it is that there's probably one or two items that they sell that do work, at least well enough to keep the myth that the others work going.
tumnasgt 11-25-2010 03:57 PM
I think that it might just be a very small capacitor (probably the whole thing is just a home made cap). Unless I'm not thinking this through right, it could simply be that without the 'device' the voltage spikes too quickly for the analog volt meter to show it, whereas with a tiny capacitor, it gets charged and holds the voltage long enough for the volt meter to display it. Being a tiny capacitor would also explain it dropping in voltage so quickly, as voltmeters usually make crap all difference to capacitors, and there is nothing else to cause the charge to drop (there is a diode stopping the coil completing the circuit).
Kyleyadon 11-25-2010 04:12 PM
I'm sure that's exactly what the device in the video was, why else would it need to be shorted across and discharged in between tests?
