Old 08-04-2012, 08:45 PM   #1 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
new premium battery user
So I got tired of standard wimpy cranking, and upped the game by $30.00 at Walmart.
Sealed battery!...my 1st in a bike.
In your experience; are these reliable, trustworthy, long in life, generally speaking?
If I can trust it; not filling w distilled water every once in a while would be a nice chore gone!
What's been your experiences?
Was blown away by about 4 times the cranking speed I've been used to!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 08-04-2012, 09:17 PM   #2 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I have no experience with bikes, but why wouldn't you use an SLA battery?
Old 08-04-2012, 10:16 PM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
They are much more sensitive to being over charged, so if your charging system is crude or out of spec it can ruin the battery right off, also because it's not flooded, when it vents there is no way to get it back and if you live in a cold part of the country some of the sealed batteries don't like getting below -20F, so if you store your motorcycle in an unheated garage the winter alone can destroy the battery in one bitter cold night.
But for a lot of people sealed batteries should work just fine, most people don't water their battery anyway.
Old 08-04-2012, 10:36 PM   #4 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Of the many bikes I have owned - old, new, big, small - I have never had a battery that worked poorly. They either worked or did not work. And I have never watered my bike battery, as they typically don't need it if they are healthy. Your SLA battery should work brilliantly. You can buy lithium motorcycle batteries now too.....
Ryland: all bike charging systems are crude. The flywheel A/C generator is always charging full blast and when the voltage reaches the regulating point, it shorts to ground inside the rectifier/regulator. A huge waste of energy. This is why the rectifier/regulator has massive fins and are usually just below the temperature of the sun (especially when you ride with the revs high), and also why they are the one thing that seems to continuously fail on a motorcycle.
Old 08-05-2012, 05:23 AM   #5 (permalink)
The GoldWing battery bit the dust; after shopping and finding the expected insane motorcycle battery prices, I took a battery out of one of the cars and put it in one of the saddlebags on the GoldWing. It has NEVER cranked over so fast!
There's a lot of individual variation in bikes as far as proper charging or overcharging; some charge to more optimum levels than others but all that I've ever owned tended to overcharge thus requiring adding water to the cells periodically.
Old 08-05-2012, 09:02 AM   #6 (permalink)
alvaro84's Avatar
Teresa - '04 BMW F650CS
Motorcycle
90 day: 80.53 mpg (US)
The YARDIS - '99 Toyota Yaris 1.0
90 day: 59.52 mpg (US)
I had a battery that worked poorly, in a sense. When it was dying, it had enough charge only for a single crank. If the bike didn't start - so much for normal starting. Bump starts still worked, tough. Of course I replaced it as soon as I realized the problem.
Old 08-05-2012, 11:33 AM   #7 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I've had a sealed Yuasa battery in my bike.
It took at least 8 years of abuse, including many months of just sitting there, being drained down.
Recharged it, and fired up the bike. Never any battery-issues at all.
After about 6 years or so, I finally got a battery tender, and kept it warm & hooked up.
I no longer have the bike, so I don't know how long it lasted after that.
Old 08-05-2012, 05:06 PM   #8 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
I like AGM batteries in Atv/ motorcycles. They just take the abuse better.
Old 08-12-2012, 07:38 PM   #9 (permalink)
larrybuck's Avatar
Thanks for the responses! I looked into the SLA online batteries. Sounded good, but I wanted the battery right away on a weekend, and Walmart was an easy choice!
Very happy so far; time will tell.
It seldom gets below 32 degrees here, and the battery would probably be resting in the house then anyway.
