EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Anyone use an OBD-II Splitter? (https://ecomodder.com/forum/showthread.php/anyone-use-obd-ii-splitter-23299.html)
vskid3 09-13-2012 06:22 AM
Has anyone had any success (or lack thereof) in connecting multiple Scangauges, Ultragauges, etc (in any combination) to the same vehicle?
I currently have an Ultragauge in my Escape. It works great, but I plan on getting a Scangauge in order to monitor the hybrid-specific gauges. I want to still run my Ultragauge, mainly because the Scangauge display would be full from just hybrid info. I've found mixed results from running them both in the same vehicle, so I would like to be able to see what my chances are.
Gealii 09-13-2012 06:26 AM
i don't think you should have any problems running a splitter between the 2. I have actually thought about it myself, so i wouldn't have to pull the plug to code read the cars that was until i learned the UG was a reader
wickydude 09-13-2012 07:16 AM
Won't you get a problem with the protocols then?
I was thinking of using a Kiwi wifi OBD thingie and my iphone/ipad...
Phantom 09-13-2012 11:17 PM
I ran a slitter on my Bonneville and my grandprix to run the ultraguage and would scan with my tuner with no problems.
