Old 08-22-2009, 03:49 PM   #1 (permalink)
SirKeats's Avatar
GeRide - '89 Geo Metro *XFi
90 day: 54.26 mpg (US)
Intermittent problem w/ Ignition - 89 Metro LSI
My 89 Geo Metro LSI is having intermittent ignition problems. By intermitant I mean that sometimes when I turn the key the starter turns over the engine, and sometimes it doesn't.
I pulled off the plastic around the steering column today and took a peek. Blew everything out with the ol' compressor. Everything looks solid under there. There is some play in the wheel when it's locked... but otherwise the whole assembly under there appears solid.
I got it to NOT start and turned the key a couple times. I can hear the starter engaging (makes a click noise)... it's just not turning the engine. I'm not sure yet, exactly, what I do to get it to start. I lock the wheel, turn it back and forth, clutch in and out, key in and out, whatever. Seems kind of random but eventually I can get the starter to turn the engine over.
Any thoughts on what the problem might be. I'm not sure how to pinpoint the issue in order to resolve the problem.
Thanks!
Old 08-24-2009, 12:59 PM   #2 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Sound to me like it is your starter motor going out. The click of the starter engaging is the solenoid, so that means you are getting power to the starting circuit and therefore the parts in the steering column should be working correctly.
Winter daily driver, parked most days right now
Summer daily driver
Old 08-24-2009, 01:51 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I agree - less likely a keyswitch problem, and more likely a starter problem. Might be a bad battery cable connection as well.
Old 08-24-2009, 03:12 PM   #4 (permalink)
doviatt's Avatar
Grey Goose (Retired) - '89 Geo Metro LSI 4 door hatch back
Last 3: 57.16 mpg (US)
Tweety - '91 Geo Metro Convertible -2 Door convertible LSI
90 day: 43.97 mpg (US)
Shadow - '02 Honda Shadow VT1100
90 day: 43.46 mpg (US)
Sonic - '07 Honda CBR1000RR
90 day: 42.69 mpg (US)
Filmore - '84 Volkswagen Vanagon
90 day: 20.9 mpg (US)
I agree also. Start with the easy one first though. Battery and cable/connection. I see this all of the time when someone has this symptom. If it starts every time with a jump start (try this). A loose connection can make is so the battery won't fully charge and can't engage the starter robustly.
Old 08-24-2009, 03:25 PM   #5 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Once I found corrosion inside a terminal lug. It checked out fine for continuity, but wouldn't pass enough amps for a starter. Look first for things that have gotten hot, and then try cleaning all connections.
Idle Speed Adjustment '89 Metro SirKeats DIY / How-to 7 02-08-2010 02:23 PM
89 metro... shift knob removal SirKeats Off-Topic Tech 5 08-17-2009 12:04 PM
89 metro lsi AC removal? SirKeats EcoModding Central 6 08-17-2009 10:57 AM
'89 Metro - Has 13's... go 14's or bigger? SirKeats General Efficiency Discussion 11 06-04-2008 11:53 AM
Just picked up an '89 metro!!! SirKeats DIY / How-to 4 05-18-2008 02:46 PM
