Old 11-19-2009, 12:42 AM   #1 (permalink)
civic ex coupe 96 not good with SGII
Hi guys,
I asked SGII guy if it is compatible with my civic ex 96 coupe.
Their answer was no .
Can someone with the same civic confirm this?
So what is the alternative here?
I have a limited electrical engineering knowledge, in order to install MPGuino.
Maybe a good old vacuum gauge is for me.
Thanks,
Old 11-19-2009, 09:49 AM   #2 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
It works fine on my 1996 civic. I think the problem is that you're in Australia - does your car have an OBD-II port?
Old 11-19-2009, 05:21 PM   #3 (permalink)
Australia civic coupe was made in US. The engine is D16Y8 which should be an OBD2, but I still need to confirm it.
Which engine is your civic?
Old 11-19-2009, 05:25 PM   #4 (permalink)
Hypermiler
Wagons
D16y7. It's the non-vtec version. I know of others with the y8 who use the SG successfully, too.
Old 11-19-2009, 06:49 PM   #5 (permalink)
Thanks for the info. I'll ask the SG guy again.
Any guesses on '83 Civic mpg? Ryland General Efficiency Discussion 10 10-19-2013 10:28 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Standard trans swap for '96-'00 Civic? brucepick EcoModding Central 6 12-17-2010 10:16 PM
96 Civic DX HB vs civic HX EngineeredCivic EcoModding Central 4 09-21-2008 08:30 PM
'93 Honda Civic DX Coupe -- Good Project Car? RH77 The Lounge 5 04-01-2008 09:25 PM
