Is Arduino Nano compatible?
Hi,
I was wondering if I can use an Arduino Nano 3.0 board with OBDuino32K. Can I? Will it make any difference in programming, etc? Cheers :thumbup: |
Atmega328 is the chip on board, there are 13 digital IO and 6 Analog.
It's definitely able to run the OBDuino & MPGuino code without doubt, the board has 'pins' on it (instead of the header 'holes') that the older boards had - to get around that, the jumper wires will need to be female->male (depending on the LCD you are interfacing with, and how your hardware will go together). It's nice to see a smaller board though! |
Great... Thanks for your explanation!
I was thinking on putting Arduino + LCD inside my car's cluster, so Nano would be perfect for that. And since I can get it by the same price as Uno, even better! :cool: |
